Bumper restoration -- How to
jamescarruthers
x 23
Post by jamescarruthers »
Rob Moss from Chevronics told me when he serviced my car that you can restore the bumpers with a heat gun. It's took me a while to get around to doing it but he is indeed right.
Using a heat gun isn't just slapping some shiney site on and waiting for it to wash off. It seems that it causes the oils lost from the surface of the bumper to be replaced or drawn up from inside the bumper itself... or, so I've read on a few other forums. In other words, a long term solution.
The result is that I have like new bumpers. This is no mean feat, considering I had some of the most faded bumpers I'd ever seen.
If you want to do it too, allow an evening;I reckon it took me about 4 hours. Give the bumpers a good wash: you don't want to be burning dirt into them!
Just work the heat gun on the hottest setting in a linear fashion about 2 inches from the surface as shown in the video. If it goes stripey you are doing it wrong... try and keep large areas warm. It's really not difficult though, I promise you.
You'll need:
  • A heat gun (the sort you'd use for stripping paint)-- I borrowed an 1800W one from a mate, nothing special
    Some Autoglym bumper and trim gel
    A few cloths, or I used paper napkins
You should remove:
All of your lights. I left mine in and worked carefully around them but it did make me a bit nervous. Your call really.
Be brave but please be reassured I absolutely roasted mine in places with no ill effects !
Before:
After (No Autoglym):
After (with Autoglym):
Video:
http://youtu.be/iFKqaMsDtoc
The Autoglym is optional but I think it's best to give the warm surface some oil to make it last.
Last edited by jamescarruthers on Sun Apr 10, 2016 7:34 pm, edited 2 times in total.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Re: Bumper restoration -- How to
Post by citronut »
jamescarruthers wrote: If it goes stripey you are doing it wrong...
or if you get a big pooole of molten plastic on the ground :twisted: :-" :roll: #-o :rofl: :rofl: :rofl: :rofl:
it does look good though, you will have to do the same to the rest of the car now :lol: :shock: :twisted: :rofl: :rofl:
"This video is private"?
jamescarruthers
x 23
Good point on the video I've never uploaded to YouTube before.
It should work now I've made it a public video, hopefully.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
jamescarruthers wrote:Good point on the video I've never uploaded to YouTube before.
Yes works now James, transforms it realy quickly doesn't it.
Does the heat soften the bumper? Fred's back bumper has a hol in it above the tow hitch and some of the plastic round the edges has peeled outwards. I'm just wondering if I can heat the edges and press them back in or if I have to cut them back to the correct profile before patching the hole?
I imagine it softens the plastic to an extent Mike. However I reckon you'd be better off removing Fred's bumper and placing it in front of a radiator for a while.
*a domestic radiator that is, not a car one*
x 79
From past experience, it doesn't last too long (maybe a year) before the colour goes off again.
I will be interested to see how it stays over time, I've never done a BX bumper (other Cits and i think a Vauxhall of all things)
Post by Tinkley »
We have been using this technique (heat with blow gun) to restore the colour to decks of Topper dinghies (and similar) for several years.
With these Polypropylene materials you don't want to get the surface temperature too hot, I'd guess about 70-80 deg C. Melt point is around just over 100 deg. If you want to weld in a repair patch a soldering iron is better but you will never get a really good cosmetic joint and match the texture. One trick for matching gelcoat textures when using Polyester is to squash Blutack onto a similar texture, remove it and then squash it onto the soft just applied Gelcoat. Works well - sometimes, depending on texture. I am not averse to a little knifing or carving with chisels on suitable textures either.
ritmo
Post by ritmo »
That's brilliant! Mine are quite faded too, was wondering whether to paint... obviously not!
I wonder if this would work on the bonnet also? Have you tried?
jamescarruthers
x 23
NOOOOOOOOO! Not the bonnet, you'll strip the paint off.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
ritmo
Post by ritmo »
:) Don't worry, not the top priority on my list. Bonnet's painted is it? Well mines not really anymore.
