Hi,
Some of you will remember the trouble I had a few weeks ago with what I thought was a suspension sphere seal failure. Howeve it has become apparent that it is the suspension cylinder that has failed. Some of you suggested that this mayhave been the case. I tried phoning Pleiades today, I pressume they are closed on a Saturday? I will have to try them again on Monday. In the meantime does anybody have a good rear suspension cylinder? I could do with one ASAP, I am not sure of the availability of cylinders until I speak to Pleiades. Thanks.
Regards Graham
Rear suspension cylinder
Re: Rear suspension cylinder
there was talk on here about the possibility's of repairing the cylinders,
maybe weld them up and re/machine the internal bore, or bore them out oversized and sleeve the bore with a stainless steel liner,
i think as long as they dont distort with the heat of welding up from the outside, and there is no blow through of weld internally this will suffice,
as the piston seal is not moving up and down the bore with the piston,
I have managed to locate a second hand cylinder from a citroen breakers in Billericay. Very helpful people. The phone number is: 01277 651 486 if anbody needs any second hand bits. Thanks.
Regards Graham
Regards Graham
Xantia cylinders will also fit with a minor modification:
http://www.rmattila.com/images/remontit ... _cylinder/
Those are nowadays easier to find than original BX ones.
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
I used a file for mine . So do you recommend fitting in pairs as the bores are different diameters ?rmattila wrote:Xantia cylinders will also fit with a minor modification
Land Rover Discovery TD5
True, the bores should be identical. IIRC, Xantia Berline has 37 mm bore, which is the same as in BX Break, whereas BX Berline has a 35 mm bore.
- MULLEY
Why can you only use the non-hydractive cylinders from Xantia's on the BX rather than the hydractive one's?
- docchevron
hydractive cylinders have MASSIVE pipes and unions feeding them!
- mat_fenwick
- x 19
The difference in area (and therefore force from the cylinders) is only about 10% so I'm sure you'd 'get away' with mismatched ones. The anti roll bar would keep the car level side to side.
