Ian_Fearn
Posts: 2231 Joined: Fri Jun 03, 2005 9:51 pm
Quote
0
login to like this post
Post
by Ian_Fearn » Sat Jan 16, 2010 5:34 pm
Does anybody have a BX heater resistor (or is it a transistor?) going spare? The one that screws into the back of the blower.
I've confirmed its broken on my BX and i'm soooo cold. Although GSF still list them, they no longer have any left.
Good money waiting
Over and out from me
Posts: 4408 Joined: Sun Aug 14, 2005 10:53 pm
Quote
0
Post
by ken newbold » Sat Jan 16, 2010 8:12 pm
If it's not blowing at all, take it out and re-solder all the connections of the PCB and clean up both side of the metal disc that's in there, I think you'll find that cures it.
I've found that only when they fail and you've got full blow are they knacked.
Stinkwheel
Posts: 1516 Joined: Wed Jan 04, 2006 9:38 pm
Quote
0
Post
by Stinkwheel » Sat Jan 16, 2010 10:56 pm
Does anyone have the number off the heater resisitor things? I work in electronics/electrics.
Good chance ive got some at work.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
Posts: 7327 Joined: Tue Sep 20, 2005 4:08 pm
x 20
Quote
0
Post
by mat_fenwick » Sun Jan 17, 2010 12:04 am
It's a PNP transistor in a TO3 case - I replaced mine with a heavier duty version from RS but I'm buggered if I can find the details at the moment. I cross referenced it from the part no. of an original transistor and replaced it with the highest current rating one I could find since I am running twin fans.
BX Bandit
Backslash Bandit
Posts: 2588 Joined: Thu Aug 31, 2006 7:46 am
My Cars: Cars
Quote
0
Post
by BX Bandit » Sun Jan 17, 2010 9:59 am
Stinkwheel wrote: Does anyone have the number off the heater resisitor things? I work in electronics/electrics.
Stinky you took the words right out of mouth, it must been while I wa.........
no, wait....
Start again.
I have what Ian wants but I think it's a dud anyway, but it's easy to hand so I'll try and read the transistor part number.
Ian_Fearn
Quote
0
Post
by Ian_Fearn » Sun Jan 17, 2010 10:24 am
Many thanks for the responses, i've been offered one now. He's going to check it works today for me.
Very interested to know what this aftermarket type resistor mod is? Could turn into more of a problem in a few years when theres no spares left.
Brian
Posts: 441 Joined: Sun Jan 08, 2006 5:53 pm
Quote
0
Post
by Brian » Sun Jan 17, 2010 5:58 pm
Replacement Regulator transistor:
2N5879/80
2N6029/30/31
2N6246
2SA1116
BD318
MUJ15016
All P Type TO3 case 15 Amps
Stinkwheel
Quote
0
Post
by Stinkwheel » Mon Jan 18, 2010 9:07 am
Ah, thanks for the compatible list Brian, saves me bothering to look
As it turns out do have a couple of the BD318 marked ones hereon the shelf
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Posts: 3586 Joined: Tue May 17, 2005 11:48 pm
My Cars: BX 16v Ph2 - Jazz BX 16v Ph2 - XPO
x 85
Quote
0
Post
by Vanny » Mon Jan 18, 2010 7:39 pm
Worthy of going in the technical archive this usefull snippet me thinks!
x 20
Quote
0
Post
by mat_fenwick » Mon Jan 18, 2010 11:51 pm
Agreed. Have moved it now! (People should still be able to post in this section, although not start new topics - please let me know if this is not the case).
To add to Brian's list is the part number FW26925A1.
For further information I replaced mine with
this, which has a part number of MJ11015 and can take 30A. Apparently the standard transistor is also used on A/C cars with twin fans, so overkill really.
kermit the frog
Posts: 673 Joined: Mon Aug 13, 2007 10:36 am
Quote
0
Post
by kermit the frog » Tue Jan 19, 2010 1:56 pm
I have to wholeheartedly agree with VANNY.
This is a definite resource which needs to be expanded so if any component parts are available for whatever is on a BX we need to try our best to list them here for future reference.
Regards Kermit
