Hi hope someone can help I need a rear height corrector valve and also potentially a distribution valve as well
thanks Paul
Wanted height corrector valve.
- My Cars: BX19 TGD Meteor
- x 3
My current fleet.
1991 BX19 TGD Meteor
1995 Land Rover Defender
1967 DAF 44 Variomatic
1975 DAF 44 Variomatic
1975 Triumph Spitfire MKIV
Re: Wanted height corrector valve.
I should have both, i definately have a few good flow valves i will check on the height corrector tmrw. I have a complete flow valve/pressure regulator set up here ready to bolt on if you're interested in that also. Had no leaks when it was removed.
