Overspray removal
Overspray removal
I have some black overspray on the roof of the white estate, i have tried t-cut but its not shifting, any ideas how i can get it off without removing too much of the original paint? The whole exterior paint is quite "flat" but in good condition otherwise, any suggestions on a good quality polish or cutting compound, i have an electric polisher to aid.
- x 16
Re: Overspray removal
I have used Farecla, G3, G5, G10. The hardest is good for using by hand, just spray a little bit of water when it gets dry while grinding to make it work again without adding more compound.
