rear o/s small leak
greendale65
rear o/s small leak
Post by greendale65 »
Hello all, i have a small LHM leak at the rear o/s
suspension can some one give me a clue is it a
big job what would i need for the job
before i start to go to the garage
i may have the part in my shed.
thanks all. :?
Re: rear o/s small leak
Could be a corroded pipe, could be a loose sphere, but could equally be a worn through cylinder. You won't know until you look.
As Defender says, impossible to say without examination.
Could also be failure of the rear height corrector as that unit is mounted on the o/s.
Good news is that the main failure areas of the hp pipes is on the n/s as they pass over the subframe, so likely (but not definitely) not that.
greendale65
Hi pleased for all the helps
something to go for
having a bx is the forums
thanks all.
