Talking B____X
Re: Talking B____X
Postby docchevron » Sat Feb 27, 2016 3:42 am
I run them all up regularly, and drive them around the farm to keep everything going. I've given up welding up knackered BX shells, I'm slowly starting to assemble decent shells from good panels and I'll most likely re-shell ELF at some point. Sick of welding patches and such, so I intend to make a batch of decent shells and have them E-coated so I shouldn't ever have to weld one again!
3 x
Re: Talking B____X
Postby Jaba » Sun Feb 28, 2016 9:13 pm
docchevron wrote:I run them all up regularly, and drive them around the farm to keep everything going. I've given up welding up knackered BX shells, I'm slowly starting to assemble decent shells from good panels and I'll most likely re-shell ELF at some point. Sick of welding patches and such, so I intend to make a batch of decent shells and have them E-coated so I shouldn't ever have to weld one again!
E-coated !! What with Chris ??
0 x
The Joy of BX with 3 too many Citroëns. RIP one is dead now so I have two too many Citroens, till death us do part.
x 11
Re: Talking B____X
Postby Philip Chidlow » Mon Feb 29, 2016 12:06 pm
Sounds like quite a project!
0 x
• 1992 Citroen BX TZD Turbo saloon, White, 94k miles
• 2003 Rover 75 CDTi Connoisseur Tourer, BRG, 145k miles.
Re: Talking B____X
Postby docchevron » Wed Mar 09, 2016 4:58 pm
Jaba wrote:E-coated !! What with Chris ??
I'll be using this lot mate. Varied responses to how well it works, but if prepped right I think it'll be fine.
http://www.surfaceprocessing.co.uk/
0 x
x 11
Re: Talking B____X
Postby Philip Chidlow » Wed Mar 09, 2016 6:33 pm
Dipping BX shells - that'll be something to see. :)
0 x
Re: Talking B____X
Postby docchevron » Thu Mar 10, 2016 6:04 am
it might be if I can get a couple into a condition worth dipping!
0 x
x 11
Re: Talking B____X
Postby Philip Chidlow » Wed Jun 22, 2016 11:23 am
It's been a while, so time for a short update.
First, the BX is still tucked up in its garage, getting the odd trip out, but not exactly being overstretched! It passed it's MOT yesterday - second one in a row to return with no advisories. So I'm happy and relieved. But checking the certificate it transpires I've done less than 2,800 miles in it since the last one! In fact, mileage is still below 100k, at 98k and I've only done 7,400 miles in it since acquiring it in August 2014.
With next year's Challenge, not to mention the Conservatoire trip and various Rallys I should see the next MOT at around 104k miles... Still what I consider low miles for a TD BX. :)
Recent work includes fitting comfort spheres and new Champion glow plugs. Even after three weeks doing nothing it fires up a treat. The ride is very nice now, although I think I will experiment with slightly firmer (standard 19D) rears as, unloaded, it feels a little tooo soft on the back. The tyres are good, but in all honesty I find them quite noisy so will fit new tyres before next spring. Ones selected for being quiet and capable.
Work and projects afoot:
Fit new foglights (collecting at the National ;) )
Getting the podded temp gauge to read right will involve a resister and magic.
Getting the boost valve diaphragm replaced - although my mechanic suggests leaving it alone. A trip to a recommended diesel pump specialist called for I think lol
Taking the plunge and replacing the coolant - which will mean I can replace hoses with the blue silicone set I have, as well as replacing the shielded ones at the back of the engine (I have a new pair).
Completing the rewiring of the lights.
Sort fuel sender issue out.
Do a bit of window surround painting.
There's a slight weep of oil from the rocker cover gasket - so do that - and the (easy-side ;) ) camshaft oil seal.
And that's about it for now.
0 x
x 47
Re: Talking B____X
Postby Kitch » Wed Jun 22, 2016 2:01 pm
Philip Chidlow wrote:The tyres are good, but in all honesty I find them quite noisy so will fit new tyres before next spring. Ones selected for being quiet and capable.
You want Dunlop StreetResponse there Phil. Got them on the AX GT, and drive a few cars with them fitted. Good wet weather grip, and very quiet.
1 x
x 11
Re: Talking B____X
Postby Philip Chidlow » Wed Jun 22, 2016 2:47 pm
Thanks, I wasn't really sure where to start!
0 x
Re: Talking B____X
Postby Way2go » Wed Jun 22, 2016 4:28 pm
Interesting, many years ago Dunlop was considered a good tyre but in PR terms has log been surpassed by the Michelin, Pirelli and even Bridgestones. Possibly the fall-out from F1 where even the Dunlop Bridges are a thing of the past?
Good to hear of an objective assessment from Kitch.
0 x
x 47
Re: Talking B____X
Postby Kitch » Wed Jun 22, 2016 5:36 pm
I wouldn't rate Pirelli that highly, to be honest. Michelins are good for quiet rides and fuel economy, but in my opinion the grip wasn't amazing on the Pilot Premacy or Energy models. The Dunlops are a bit cheaper, and every bit as good on the cars I've driven them on as more expensive rubber. I'll be getting some for BAH when the current budget ones fall apart.
Dunlop SP9000 is to this day, the best road tyre I've ever driven on, but they don't make them anymore.
0 x
Re: Talking B____X
Postby Defender110 » Thu Jun 23, 2016 2:05 pm
Kitch wrote: Dunlop SP9000 is to this day, the best road tyre I've ever driven on, but they don't make them anymore.
Still showing readily available on the net or are you just referring to one particular size?
0 x
1987 Citroen MK1 diesel estate.
1974 MG Midget 1500 (in need of restoration)
2010 BMW X1 SE 2.0D Auto
2003 Land Rover Discovery TD5
1993 Land Rover Discovery 300tdi 3 door
x 47
Re: Talking B____X
Postby Kitch » Thu Jun 23, 2016 2:38 pm
I think they're out of production, but it might be there are certain sizes left in stock. The sizes I was using were 205/55R15 and 225/50R16 (TVR Chimaera 400 front and back)
0 x
x 11
Re: Talking B____X
Postby Philip Chidlow » Sat Jul 30, 2016 12:49 am
OK, posted on the FB page, but I thought this belonged here too:
As many will know I am a fan of the C4 Cactus. OK, it's not to everyone's taste. It's not roomy in the back, it has limited performance and it looks, well 'odd' to many. It does have good load space, a pliant ride, it has reasonable handling and visibility is better than many new cars (except the rear). It is however surprisingly tough! It's got good economy too - around the 60mpg mark overall. There are some quirky design touches and it certainly looks different than other cars on the road (it couldn't be mistaken as anything other than a Cactus). It's also proving popular and I am seeing more and more of them on the roads. So in some ways it heralds a return to form for the marque.
But hang on. I took my 1991 BX TZD Turbo diesel hatchback for a 'country drive' last weekend... And to be honest, it does most of what the above does - and shares many of the traits of the Cactus - at a mere fraction of the cost (and let's face it - it's 25 years young) ie: Not to everyone's taste, cramped in the rear, good load space, ride and handling OK, good visibility etc... So although I am in no doubt as to the Cactus's merits as a vehicle (regardless of when it was made), it's not a quarter of a Century better. It is instead an fairly good reinterpretation of the BX. Less, of course it's much cursed but equally loved hydropneumatics.
Sorry. My BX might cost a bit to keep going, but to get a decent Cactus will cost £16k so I know what I'll be doing: Keep the BX alive regardless of cost and pocket the savings even though road tax, fuel duty and legislation might conspire push up costs.
Your BX is not just as good as a Cactus. It's better!
0 x
x 43
Re: Talking B____X
Postby Tim Leech » Sat Jul 30, 2016 8:34 am
Wait a few years phil and buy one when they are £5000! It won't take too long!
0 x
1985 BX 19GT Mk1
1991 BX 19TZI Auto A/C
1990 BX 16TGS Athena
1991 BX 17 TZD Turbo
1994 Xantia 1.8i SX
1998 Xantia 2.0i Desire II Auto
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
2001 MG ZT 190+
2002 Rover 75 CDT Connossieur SE Nav
2003 Rover 25 1.6i XL 5 DR
Return to “BX Blog spot”
Who is online
Users browsing this forum: No registered users and 1 guest
