As some of you know, my BX estate is almost complete. i really need to remove the side vent panels so i can get the car resprayed.
just how do you remove the trim panels on a BX break / estate?
i will at the same time replace those bits of foam / sponge looking material that has all but broken up and disappeared over the years.
what holds them on? does anyone have any pictures of a BX without the tim panel vents on? (so i can see where it is held on).
thanks guys!
Side trim C pillar vent panel removal
- Dragon Man
- My Cars: Citroen Dispatch 2.0L HDi 2005
Fiat Panda 4x4 Sisley 1991 - x 6
- JohnDragonMan
Drives: Citroen Dispatch with retrofitted air conditioning
always buy base spec. that way you have the fun of putting all the cool bit on your vehicle
- x 16
Re: Side trim C pillar vent panel removal
I do have a stripped break (actually Van) standing on my yard, if no-one is quicker I'll try to make photos tomorrow if I can breath outside the house without beind drowned...
- Dragon Man
thanks! it will be very handy
- JohnDragonMan
- x 16
Here you are, just click on her to get to the gallery. Includes some pics as an added bonus!
(The gallery contains a lot of pics and info from our fellow ethusiasts so take your time browsing around)
PS. No animals were harmed while taking the photos, the pig was allready breathless .
- Dragon Man
thanks for the pictures. i was looking for pictures of the vents on the outside of the car being removed.
there must be a way to take them off without damage surely??
- JohnDragonMan
- x 16
Sorry I understood you want pics from inner trims removed. Does the break have bolts like hatchback? If not, I think they are glued . If you want you can come and try to remove them, no harm done if they break because the car is going to be scrapped anyway .
- Dragon Man
hmm so its bolts that hold them on from the inside maybe?? i will have to do some research on this..
- JohnDragonMan
