If no-one on this forum has one for sale, does anyone have any suggestions on where I might try?
MPN is 95560675. Year is 1988 (early), although I doubt that matters much.
Thanks,
Jim.
Wanted: Driver's Window, Bronze tint
- x 141
Re: Wanted: Driver's Window, Bronze tint
Hi Jim
The earlier cars were bronze and after 1989 they all went to a green tint.
The place to try is chevronics and if he doesn't there is Alan Goodyear's BX graveyard in Whitlesey
- My Cars: 1988 BX 19 GTi
1996 Renault Laguna 2.0 RXE Family
2008 Renault Grand Scenic 2.0 DCi
Thanks Tim,
As it happens I've already tried Chevronics, who have a clear one - which I'll probably go for, as I can then at least get the car back on the road.
Will give Alan Goodyear a call in the morning - appreciate the pointer, I don't think I knew about them.
I had a later (K reg - early '93 if I remember correctly) 19GTi as a company car. I do, however, clearly remember it having green tinted glass - but I assumed that this was because the body was white.
Do you think all the later GTis - even the Red ones - had green tinted glass?
Jim.
Jim.
- x 141
The window tints was the same on all colours but changed on trim level and year, most early cars were clear with a bronze tint available as an option, then from 89/90 they went to green until end of production I think. By the end of production most cars has tinted windows asides the E/TE models.
- x 88
I might have one on the DTR breaker, but I'd need to double check.
I've got a window from a turbo diesel not sure which tint get you out of trouble if you're stuck
Update:
Not long after my last reply, I got a clear window - from Chevronics - and fitted that. Took ages to clean up all the broken glass!
So at least it's back on the road and my need for a bronze window is no longer quite as urgent.
Kitch & rutter123 - thanks for replying, would you mind checking whether yours are bronze? Tint code (at least on my 2 original windows) is 43R 000929.
However these tint codes are a bit of a nightmare. On the remaining 5 pieces of door glass - all of which seem to be bronze - there are 4 different codes!
So does anyone have a definitive list of tint codes that they could share with me?
Thanks again,
Jim.
Thanks again,
Jim.
