Rubber Bungs Located
- x 141
Hi guys
I need the two rear bungs for the nsr floor, mine have dissolved, is for j119, looks like a battery spilt in the rear footwell and it melted the carpet!
Thanks
Thanks
- Vanny
BX 16v Ph2 - XPO - x 79
Re: Rubber Bungs Wanted
Do you know what size the hole is? I've got a box of used ones of differing sizes.
Do you want them posted or do you want to collect?
- x 141
Thanks Vanny
I have located some mate,
- x 141
Nope, change of plan I still need them.
- x 141
Anyone, surely someone has a car being stripped?
Re: Rubber Bungs Located
I'm going to look at a car that's being broken tomorrow Tim, I can see if it still has the bungs in the footwell if you want ?
- x 141
Thanks Andrew, Barry has come to my rescue mate, cheers though,
Is this the low mileage meteor? Seen on Facebook? If so what a waste!
No not seen a Meteor being broken, the one I'm off to is a silver TXD Turbo, 81K on the clock, Im going to get anything that is left that might be of use to others or myself, will probably have parts to move on at rallies so if there is anything you might need I can try and get hold of it.
So far all I know thats gone is: door cards, front and rear seats, side stripes, bumpers,headlamps and adjusters, spoiler, rear lights, heater dial.
Not sure how much will be left by the time I get there tomorrow.
Glad you're sorted for bungs though.
Made my salvage run, that TXD is in stunning condition in most of the usual 'problem' areas. It's an absolute waste! If I had cutting tools I'd have taken a lot more of that car with me.... but I did manage to save some bits and bobs from it so not all is lost.
-Valeo TD radiator with top hose (couldn't get the bottom one)
-Twin fans
-Hydraulic pump
-Accumulator sphere (probably dead) but all the gubbins/FDV that it screws into
-Black glove box, coin holder and ash tray
-Both front wings in silver paint code ECYcR
-All four buttons from dash pod
-Seat base from passenger seat and headrest (couldn't get the torx bolts out to remover the whole seat as my torque screwdriver died and the torx bit wouldn't fit any of the spanners or sockets I had on me)
-Rear number plate lights with good retaining clips
Not a wasted trip by any means.
-Twin fans
-Hydraulic pump
Tim i prob got most of the bungs on the t/d scrapper if you need spares for the future, its pretty much a bare shell now and i cant get anyone to take it away as its worthless as scrap, will prob end up cutting it up into small pieces and taking them to the tip bit by bit.
I got some rubber bungs off of ebay for the chassis plugs think they were either 32mm 0r 35mm diameter fitted nice and tight and a few quid for a pack of 10.
- x 141
Thanks Cliff
Barry Annells is sending me some, could you remove them from your scrapper just invade they don't show up.
Thanks
Thanks
Yeah no probs Tim i will pull out as many as are still any good and bag em up.
