Guys who did the cambelt said the bottom hose is getting a little tired.
Tryied my usual contacts but no joy!
Any ideas?
BX 1.9 Petrol bottom hose
- x 150
- Jaba
- x 83
Re: BX 1.9 Petrol bottom hose
If the hose is still intact then what I do sometimes is to use self annealing silicone tape wound around the weak areas for reinforcement and so far have had no failures.........
- x 150
Hi John
Its the end of the hose where it is starting to degrade,
- Jaba
- x 83
Tim Leech wrote:Hi John
You can still use the tape on the end under the hose clip and use silicone sealant afterwards inside to fill the splits/cracks. It will get you out of trouble for a long while until you can source a better hose. I presume the hose is not one with a provision for a smaller hose to connect somewhere along its length.
- x 150
Hi John
Yes its the one with his another smaller hose feeding off it, and is proving difficult to find.
Kitch did you fit a new one to your Dads?
- x 150
Sorted, ive crosss referenced the part number on chevronics website of 95610898 and got one sorted.
- x 88
Nah, his was in pretty good condition, though it's going to be running waterless coolant, so it won't be under any pressure anyway.
- Jaba
- x 83
I think I have got one of those hoses somewhere if anyone has the need.......
