graphite bx estate tzd
Cromptons
Post by Cromptons »
I bought this car off Nick (in for sale section) for a massive £300.
The end intention is is to use it (and a peugeot 305 estate) for a mates euro trip next year.
I already own a Citroen zx hatch 1.9td engine giving roughly 180-200hp ( big turbo, heavily modded fuel pump, rebuilt engine etc etc etc), and a black zx 16v and just acquired a xm 2.1.
The bx so far has had
heavy internal clean
2 front spheres and accumulator (made an amazing difference!)
New long drive shaft (yet to fit)
near side drop link
engines had a slight tune but clutch is totally knackered
Other bits and pieces what I can't remember. but so far quite impressed with the bx (my first one to own/drive).
Jobs to do
change rear spheres
clutch
leak on pressure regulator (looks like the end oppo the accumulator?)
poss engine change to a 1.9
Unique bx parts i need: (expect this list to grow)!
head rest is missing from drivers seat, which has for some reason been swapped onto passenger side (whole seat)
possibly a tailgate as lock unit has been smashed from plastic support
Cromptons
Re: graphite bx estate tzd
Post by Cromptons »
bx with the zx td and the 305 euro car.
zx 16v
bx engine bay clean
after first interior clean
Welcome & an interesting collection of cars :) Look forward to reading more in your blog.
Post by Tinkley »
Although it might be tricky, check your droplinks are the same length. There is quite a bit of variation and some members have reported cars steering to one side because of differing lengths. My last pair were 7-8mm shorter than the ones they replaced.
Good luck with the car.
bxzx16v
Post by bxzx16v »
Welcome along James, that's quite an interesting collection you've built up, how's the ZX16V going?
Mark (with the green 16v)
Cromptons
Post by Cromptons »
Update!
It performed very well on trip in May to italy and back.
Now it's been treated to a xud9 engine with a 2052V turbo
x 151
Lovely. Not sure about the pink wheels though lol
Post by Tinkley »
Don't worry Tim, the rest of the car is bound to follow suit..... :lol:
Cromptons
Post by Cromptons »
Arrghh! My eyes!! lol ;)
Is that an exhaust I see poking out in front of the rear wheel?
Post by Mothman »
I like the Cornish flag too.
themildbunch
Post by themildbunch »
love the engine mods you've been doing - be good to read more details about these.... thanks for the lucas pump and injectors you dropped off.. what happened to the old engine?!
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Cromptons
Post by Cromptons »
Adrian, hello
Old engine donated a lot of its ancillaries to the current engine, also hg was on its way (still perfectly drive able). (If anyone wants any bits and an unopened hg then shout)
The only reason I dropped a 1.9 in as you can't get mls gaskets for the xud7
Keeping power sencible 15/16 psi should do around 140hp, but with it being a vnt turbo be very responsive and help with having the hdi gearbox.
Having a few issues
Clutch slipping, need to convert to a pull type and fit a paddle clutch
Heater matrix on way
Tick time down to about 8 secs ( been like it a while) but after fitting new engine went up to about 50 secs, but now back again to 8ish
+ plenty of small niggles!
x 151
You get plenty of niggles with a BX, just so you don't get complacent!!
Post by Tinkley »
Cromptons wrote: Tick time down to about 8 secs ( been like it a while) but after fitting new engine went up to about 50 secs, but now back again to 8ish
If you mean hydraulic system tick time, most likely, the accumulator sphere needs changing. Maybe the others, if you don't know when they were done?, although they affect the ride quality more.
