alloy wheel compatibility
arlever
My Cars: citroen bx 19rd (now sold)
citroen bx 17tgd turbo repairs ongoing. (gone to the scrapyard in the sky)
citroen cx familiale awaiting possible restoration. (rotted away)
citroen bx 14 re. this ones a beauty.
classic mini race spec.
Post by arlever »
can anyone tell me, will 15" peugeot 206 alloys go straight on my 1991 bx 17 tgd.
thank you in advance.
andy.
x 151
Re: alloy wheel compatibility
They should do yes. Just check for clearance, plus as it's a 17TGD it may not have power steering so fitting wider wheels may make it heavy.
arlever
Post by arlever »
thanks. do you know of any thinner alloys that will fit or perhaps i will just get the steelies powder coated or done up.
x 151
Personal choice, 205 Gti's fit straight on and can look good, I prefer the stock look but a nice set of rims can looks much better than rusty steels.
206 alloys usually have a bigger offset, so sit inside the arch a bit too much
hilarystone
My Cars: Citroen BX 16V, BX Van 16V, Visa GTI, CX Ambulance Turbo diesel, Xsara VTS Phase 1 and 2, Lotus Elan 1970, Clan Crusader, C8 2l petrol, 1982 GSA Pallas, 1974 GS Birotor
Post by hilarystone »
I would suggest the early C5 'steelies' which are aluminium though look like steels and weigh half the weight of a 16V alloy and have the correct offset.
Hilary Stone
http://www.Hilarystone.com
hilarystone wrote:I would suggest the early C5 'steelies' which are aluminium though look like steels and weigh half the weight of a 16V alloy and have the correct offset.
They're aluminium??
hilarystone
Yes… And weigh under 5kg each…
Hilary Stone
What do they look like?
hilarystone
Here's set on my van:
and a set repainted in white on Ebay here:
http://www.ebay.co.uk/itm/Set-of-5-Citr ... SwDiBZF~~z
They are noticeably thicker than steel wheels and there are two versions – ones which take wheel bolts with flat captive washers and ones which use wheel bolts with a taper. As I understand it the ones for wheel bolts with flat captive washers were prone to cracking…
Hilary Stone
I guess the only downside is they still look like steelies! Be good for track cars though.
hilarystone
Yes but I think that's a positive!
Hilary Stone
hilarystone wrote:Yes but I think that's a positive!
Win-win for you then! :lol:
