Wanted: alternator tensioning nut/bolt & wheel arch bung
- x 26
Am in need of the rectangular bung that sits in the offside wheel arch and which you remove to access the engine mount nut.
Somehow I have also lost the combined bolt/nut that you screw the tensioning bolt into on the alternator for a 16v model (it may be the same on other models too?). It's basically a small cylindrical thing with a thread on one end and a threaded hole on the other. Such things probably have a special name but I'm not party to that...
Rob
Rob
- Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
ZX Volcane keeping others going - x 61
Re: Wanted: alternator tensioning nut/bolt & wheel arch bung
Is it #3 on this pic Rob, if so, it is called a capscrew on the parts list. Part number 96000783.
Someone may have one. Can't seem to find one online but a more thorough search may do it.
- x 26
Hi Dave that’s exactly right, many thanks!
- Dave_16v
BX Gti past
BX Gti Auto past
Having looked, they come up as a slider bolt or tensioner adjustment arm bolt for various vehicles so perhaps another make may fit. I imagine somone with the right tools could fabricate one if you get stuck.
- white exec
Why is that pivot bolt so special - apart from having a plain shank section?
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 52
My interpretation of the diagram above is that bolt 4 screws into the threaded hole in the side of the "head" of bolt 3.white exec wrote: ↑Tue Oct 20, 2020 7:24 am Why is that pivot bolt so special - apart from having a plain shank section?
- Dave_16v
BX Gti past
BX Gti Auto past
I was going to post a pic but you beat me Rob.
Anyway, here it is now I that I managed to get it.
- x 26
now you’re making me all nostalgic for my missing bolt!
- white exec
A slightly different arrangement on 1769 and 1905cc, but might be usable?
The part (#5) is shown still available, and was fitted to all these:
1 document(s) found for BERLINGO VP
1 document(s) found for BERLINGO VU
1 document(s) found for BX
1 document(s) found for C15
1 document(s) found for C25
1 document(s) found for DISPATCH I & II
1 document(s) found for RELAY
1 document(s) found for XSARA
4 document(s) found for ZX
Hi Gents, I've got a box or three of spares, trying to find the right part for Rob and thought that I had, but not so sure now. The only image that seems to display is the parts drawing by white exec, above. I can see part number five but it doesn't seem to tie in with the description?
Thanks!
Thanks!
- white exec
I think that the threaded-head bolt, and the studded bracket in the parts diagram, may be interchangeable. The both appear to do the same job with part #3.
- Dave_16v
BX Gti past
BX Gti Auto past
If that means you cannot see my diagram and pic, perhaps there is something in your display options that could be changed. User control panel, board preferences and look at edit display options and display images within posts. Seems strange how one image shows though, if I change mine, it is all or nothing and just links.monkeyfeet wrote: ↑Mon Nov 09, 2020 9:14 am The only image that seems to display is the parts drawing by white exec, above.
Thanks!
Otherwise, your browser is not opening .jpg images because white exec's image has a different format. He appears to have uploaded them direct to the site where as mine are from an external host.
I'm the meantime.
Hi Dave,
On a work PC, must admit it's quite locked down. Anyway your image above is pretty clear!
- Dave_16v
BX Gti past
BX Gti Auto past
That explains it, pleased you can see the pic.
