PcHeaven's 91 Meteor. One owner 18,000 miles
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 70
Re: PcHeaven's 91 Meteor. One owner 18,000 miles
Post by white exec »
Radiator bottom (and other) hoses
A search on your VIN brings up...
BX 1.6L (XU52C) carburettor
RPO 5139 (= 4 Dec 1990)
BVM5 4x2
Single A/C
"Image" special spec
Coolant hoses for the 1580 carburettor engine...
Two shown, cars w/ and w/o A/C.
Both NFP.
Couldn't find either on Pieces de Rechange, Mister Auto, or Metalcaucho.
The hose internal diameters are at least shown, so mighty be possible to use general-purpose straights and bends.
Didn't realise you had A/C on it, Marc.
Pcheaven
x 12
Post by Pcheaven »
many thanks for this.
No, I don't have AC, nor was it ever fitted
I am not sure I am reading this diagram correctly. - part 6 looks possible.though I dont believe it has a T piece with a another pipe attached - part 12. could be wrong.
The hose I need comes out of the bottom of the radiator - drivers side, stays below the crank and comes in behind the engine - I can't see where.
You can see a small section of the pipe from the lower wheel arch - this is the section of pipe that rubs against something ( one sort of arm, it was explained to me but I forget). apparently not an unknown issue.
Again, many thanks for looking for me.
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
Pcheaven
x 12
Post by Pcheaven »
edit - perhaps I typo'ed the VIN wrong. Here is a photo.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
white exec
x 70
No, VIN number was right, and that's the diagram that comes up, both via the VIN, and via a BX 1580cc search.
Factory spec definitely says A/C, but likely just an arror - not unknown on the system.
Hopefully someone else can help identify the hose.
Pcheaven
x 12
Post by Pcheaven »
Thanks again. Is the bx1580 the 72hp engine. Do you know.
Even today it is not unknown for manufactures spec to differ from actual car. Last year we got a new discovery sport hse. Manufacture listed rear entertainment screens. None were fitted.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
white exec
x 70
List of XU petrol engines here:
https://en.wikipedia.org/wiki/PSA_XU_engine
According to Servicebox and VIN, yours is the XU52C.
Pcheaven
x 12
Post by Pcheaven »
white exec wrote: Mon May 03, 2021 5:32 pm List of XU petrol engines here:
Thanks
91hp - happy days.
Though currently has around 15hp, misfires and close to undriveable. Removed and checked the plugs -all good. Though HT leads are stiffer than pipe cleaners. So suspect they are part of the issue. New leads on the way. :)
Thanks again.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
white exec
x 70
Marc,
Although maybe not actually connected, while looking up info today on your Meteor (which I think is essentially a carburetted 16TRS), the year of the car rang a bell. So a link to this post:
viewtopic.php?p=268719#p268719
I have no idea whether the flat-spot issue was ever finally addressed for production vehicles, and I can't help with translating those two Peugeot parts into their modern PSA part numbers.
You've got plenty to sort out anyway, but I thought I'd throw this in.
Pcheaven
x 12
Post by Pcheaven »
white exec wrote: Mon May 03, 2021 9:16 pm Marc,
Thanks
Weirdly I had read this before.
No flat spot. Just intermittent Mis fires, so replacing plugs leads and possibly ignition module. Fuel filter looks good.havnt stripped carb yet.
When it’s running smooth I may try rejetting to see if I can get a few more HP
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
x 150
Has she had a good run? Sometimes some fuel system cleaner and a good blast can help..
Pcheaven
x 12
Post by Pcheaven »
Tim Leech wrote: Tue May 04, 2021 10:23 am Has she had a good run? Sometimes some fuel system cleaner and a good blast can help..
Yes. Over 200 miles on the motorway recently
I also noticed that the fuel filter was only about 30% full of petrol. Seems low to my inexperienced eyes.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Pcheaven
x 12
Post by Pcheaven »
Today was a sad day, I had to take the virginity of my front nearside door card, and remove it. :(
In other news, I was able to install a replacement door mirror ( Thanks to Rutter123 for supplying the part ). happy days.
Sadly, despite my best efforts - parking the car in the sun so the door and the inside of the car was nice and warm, one of the door card plastic retainers didn't survive the ordeal.
I am not replacing the door card as it refitted back to the door just fine. Though am considering making up a retainer - just for kicks, as I have to remove the door card again in the future to upgrade the speakers and install sound sound deadening.
RIP plastic "thingy ma jig"
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
x 137
I'd make a few spare retainers, as retainer loss/breakage is on average 1 per door card removal, I found a few broken ones laying in bottom of door and now down to 4 holding the door card on.
Pcheaven
x 12
Post by Pcheaven »
Apologies, I should have mentioned before.
New HT leads cured the terrible mis fires, she now drives very well
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Pcheaven
x 12
Post by Pcheaven »
white exec wrote: Mon May 03, 2021 1:19 pm Radiator bottom (and other) hoses
BVM5 4x2
Single A/C
Both NFP.
Thanks again
Seems I was mistaken ( not unusual according to Mrs me ) part 6 does look correct, as you mentioned - I can’t find stock anywhere :(
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
