The definitive heater modification
Ladies and Gentlemen ...
The heater control modification. Enables the fan to run at full speed using the relay already fitted above the steering column.
Whilst you have it apart, clean the track behind the control with a cotton bud moistened with alcohol and the contact strip on the knob itself. Also worth checking/ changing the bulbs.
And there you have it ... warm feet AND a defrosted screen at the same time
Reassemble, ajourn and celebrate your hard work with a beer...
Doz
2007 Citroen C1 (it's not a real Citroen)(With a complete set of wheel trims)
2006 C4 1.6VTR+ (Alloys no wheel trims)
1982 Mini HL (No wheel trims, no wheels)
1993 Kawasaki GPZ500
- Citroen Sorceror
- x 88
This could be done from the front could it not? Without pulling the whole panel out and trying to unhook all the cables etc?
Can't see why notKitch wrote:This could be done from the front could it not? Without pulling the whole panel out and trying to unhook all the cables etc?
Doz
- x 88
So cut a section out of the strip and solder between the other two?
- Citroen Sorceror
I'm glad I asked! I'll be a bit disappointed if I find I don't have this type of PCB when I get the panel off this week-end...Why do I modify the pcb you refer to - and how!?
This forum thing is dead good - can't beat having your own team of mechanics on tap, just waiting to offer helpful advice Cheers, Chaps - I just hope I can get to be as helpful one day when I've learnt more about BXs. My previous 2 cars were Japanese sports cars - MX5 and MR2 - and lovely tho' they were, they were also a bit boring in that I never had to anything to either of them (except replace the clutch slave cylinder on the MR2 - useful training for the BX cam belt change as it requires small hands and double-jointed wrists and elbows... )
Simon, Bristol UK
('91 TZD 1.7)
('91 TZD 1.7)
A step by step guide....
1) Pull off control knobs, and undo two philips/torx screws behind temparature and feet/face/screen knob. Turn air control knob on centre console vents to off (prevents springs from disappearing into the air duct) GENTLY remove vents, catch little springs.
2)Locate metal retaining tags just behind the vent holes to left and right, and hook a flat screwdriver behind the tag and prise it outwards to release the front panel.
3) Cut the track carefully using a pocket knife or similar (ask an adult to help at this stage!) and solder some wire across the other track.
Your circuit should now look like this:
Switch the ignition on , wind the wind control to max, you should hear the relay behind the steering column click, and the fan speed pick up. Check the bulbs , and reassemble!
Cool ....
Cool ....
Doz
I think I'll have to find the soldering kit - and fix the bulbs - I wasn't going to bother but this seems to make removing the switches worthwhile!
Paul in Normandy - BX 1992 Millesme 1.9D, 1999 Peugeot 806 2.1 TD (the Bus) - gone bang on the M25, in a scrapyard somewhere in the SE of England, 1985 Visa Decouvrable, 1990 Land Rover 110TD (Great Uncle Bulgaria),1999 Isuzu Trooper, 1991 Hymer motorhome with Peugeot J5TD power, and a shedfull of mopeds!
- Philip Chidlow
- x 25
The speed control on BX heater fans is achieved by the use of transistors which do a very good job but always have a residual resistance. The system is designed to remove this residual resistance by simply bypassing the transistors to enable full power to be delivered to the motor - and they did it rather nicely using a relay rather than a big switch on the dashboard. The only shame is that someone got the circuitboard wrong!
As for motor life - its designed to work in this way. Its not compulsory to run the thing flat out all the time - and you would probably get too hot anyway! Full speed is only achieved when the knob is rotated fully clockwise, the variable slower speeds remain undisturbed.
