BX Gearbox swap: 1.7td gearbox onto 1.9d engine
ladonamobile
Got the 1.7td gearbox on the 1.9 engine
Post by ladonamobile »
I forgot to update the list on my progress.
I did have to get a new (reconditioned) clutch, only £30 from a place in Brighouse. When I took the old clutch plate off, I discovered the female center splines had been mashed by my attempts to ram the male driven gearbox shaft into it off-center. (ooh err missus).
So now I have a nice new clutch and a taller geared BX1.9, so fuel is even better on a run. Although I sometimes have to use fourth gear on the steeper M62 inclines.
One top tip for this project is my discovery of how much help a scaffold pole, a fulcrum toolbox and a ratchet strap can give to a one man attempt at lifting a gearbox up into an engine bay.
Sliding a gallon container of engine oil along the pole gave perfect conterweight control so I could lift the gearbox with one finger from underneath the car.
Thanks to all who helped me brainstorm this problem.
1994 BX 1.9 TXD Estate bright red
1993 XM 2.1 SED rare green
1993 XM 2.1 SED winestain maroon
