BX 19 TXD - Looks like being re-listed on EBay come the 12th
Post by RxBX »
Roverman wrote:
Defender110 wrote:
Roverman wrote:Only needs a VIC check if and when you sell it on.
If they will not issue RFL reminders until it has a VIC then surely they are saying you should have the VIC done before putting it back on the road?
Can only speak for us Kevan, we had a reminder for the Rover 2 months after the write off, we taxed it at the local PO as usual with no problems.
Kevan,
This is 100% correct the DVLA does NOT send out a reminder to the vehicle owner for the RFL or SORN once a VIC marker is set against it !
Tim,
You should be aware that the DVLA are usually Slooooow when it comes to up dating info on their data-base, also the insurance company may have had the notification lying in a clerks in/out tray a while before informing the DVLA and therefore the scenario /\ may have not got captured/updated on to the DVLA database prior to the last/current invitation for you to renew the RFL or SORN notification.
Next year/time you will find that the letter/reminder will not be sent out, also bear in mind that you run the risk of being stopped by the Police when a vechile which has a VIC marker set against it, as it will also show up (Eventually) on the Police's ANPR data-base as needing this VIC inspection by VOSA !
(Tim, if you need/want to know more, I can explain it in more detail, just give me a call).
:D
GaianB
SOLD - ITEM CAN BE DELETED
Post by GaianB »
Assuming it is collected today!
