Rear disc removal
The caliper is probably seizing up on the slider pins, you need to undo the pins and clean / lubricate them. This can usually be done without having to undo the pipes Leaving the caliper in situ. You may however find the slider seals have perished which is a problem as repair kits with just the pins and seals in are just as expensive as a complete caliper off ebay. My split seals are currently coated in thick grease untill I can locate a cheap source for the pins and seals as the actual main hydraulic side of the caliper is perfect.
Riku, thanks for the diagram, I may be able to fashion something, but certainly lack many of your skills! Cheers.
Defender - that sounds about right, definitely one of the seals looks pretty ropey, I'll try the thick grease method as a stop gap. Many thanks.
Martin
I think you are getting mixed up with the fronts here. The rear calipers are different, are hard mounted and have a piston in both halfs. So unless I am misunderstanding you, there are no slider pins on the rear brakes?Defender110 wrote:The caliper is probably seizing up on the slider pins, you need to undo the pins and clean / lubricate them. This can usually be done without having to undo the pipes Leaving the caliper in situ...............
Although the subject title is rears; he was asking about the nearside front on his last posting.Way2go wrote: I think you are getting mixed up with the fronts here. The rear calipers are different, are hard mounted and have a piston in both halfs. So unless I am misunderstanding you, there are no slider pins on the rear brakes?
Sorry for the confusion! I'm going to get greasy tomorrow evening.
Martin
- mat_fenwick
- x 19
Now then! Didn't get a chance tonight, oh well.
Martin
