Page 1 of 3
Jeths lowering project
Posted: Thu Sep 06, 2012 3:09 pm
by Jeth
Heres my current BX project
Originally it was 1.4l carb with 4 speed gearbox and no fancy electronics anywhere
Spec list:
16V D6C engine
2,5" exhaust
One layer of Dynamat from roof to floor
16V interior
Front lowered about 10cm from original now with 2cm ground clearance in lowest position
Fondmetal 4000 rims in 15x7 size
Re: Jeths lowering project
Posted: Thu Sep 06, 2012 3:21 pm
by Dollywobbler
Not really my cup of tea at all but looks very nicely done. There are some right lash-ups about but that certainly has something about it. How does it ride?
Posted: Thu Sep 06, 2012 3:47 pm
by Jeth
Dollywobbler wrote:Not really my cup of tea at all but looks very nicely done. There are some right lash-ups about but that certainly has something about it. How does it ride?
Well i've mde front end quite stiff so it wont rub all the time, still alot better than people with "normal" suspension
Posted: Thu Sep 06, 2012 3:54 pm
by Dollywobbler
I suppose a BX always has that advantage! Great that people are choosing to modify cars that aren't just Volkswagens. There's far too much of that over here! (by modify, I mean cover in nitromors to remove the paint, angle grind a few suspension coils off and fit a roof rack. That's what I mean by lash-up!)
Posted: Thu Sep 06, 2012 10:24 pm
by citsncycles
Not sure about the alloys, but love the rest - I don't usually like white cars!
4 Speed box? never knew they fitted one to the BX!
Posted: Thu Sep 06, 2012 10:28 pm
by MULLEY
Is that the suitcase engined version that only had 4sp?
Posted: Thu Sep 06, 2012 10:57 pm
by Jeth
There's original engine.
And heres how car looked before i started doing it
Pic of the parts car:
and the reason why i didnt repair that one
Posted: Sun Sep 09, 2012 7:45 am
by mike22861
Suitcase RE has 5 gears
Posted: Sun Sep 09, 2012 9:00 am
by mat_fenwick
The very base BX in the UK (no trim level, simply BX) had a 4 speed 'box and 62bhp rather than 72bhp. Other countries may have had different models.
Do you think that clear side repeaters would suit it better?
Posted: Thu Sep 13, 2012 1:15 pm
by Jeth
mat_fenwick wrote:Do you think that clear side repeaters would suit it better?
In my opinion it would look too white with clear side repeaters, which is why im gonna change front repeaters to orange
Posted: Thu Sep 13, 2012 9:57 pm
by Mike P
On the picture above, did you manage to remove the bodykit from the rear arch without damaging it or did you have to sacrifice the bodykit by destroying it to save the inner metal wing underneath?
Mike P
Posted: Thu Sep 13, 2012 10:35 pm
by mat_fenwick
Jeth wrote:In my opinion it would look too white with clear side repeater
Good point. Maybe smoked ones? Anyway, it's your car, so whatever looks best to you.
Posted: Sat Sep 15, 2012 11:50 am
by Jeth
Mike P wrote:On the picture above, did you manage to remove the bodykit from the rear arch without damaging it or did you have to sacrifice the bodykit by destroying it to save the inner metal wing underneath?
Mike P
Heat blower works really well, so yes, without damaging anything.
Posted: Wed Sep 19, 2012 12:08 pm
by Mike P
I guess on the back of the metal arch, so that the heat goes into the mastik and does not damage the bodykit?
I've managed to remove the bodykit sections from the sills before but never a rear arch.
Mike P
Posted: Thu Sep 20, 2012 9:32 pm
by Jeth
Mike P wrote:I guess on the back of the metal arch, so that the heat goes into the mastik and does not damage the bodykit?
Yeah, heat it until it starts to smoke, then carefully try to strip it off.
