Xantia Headlights
- Sir Jim of the Databases
That is silly cheap Mike but knowing Lidl, they're most likely to be of reasonable quality as well. I've never yet bought anything bad from either Lidl or Aldi.MikeT wrote:I saw Lidl had the H1's at a very reasonable £2.50 a pair! Otherwise ebay is full of choices.
It is just a shame they cater so poorly for vegetatians otherwise I'd never need to go to Tesco ever again
Jim
Best AND most affordable???tim leech wrote:whats the best and most affordable direct replacement
Best for the price are probably GSF's Osram Silverstar H1 & H4 for £15.50 and H7 for £20.00, both + VAT - CCC discount.
Most affordable could be Euro Car Parts' Astrum H1 at 40p(!), Bosch at £1.90 or Lucas at £2.30! I guess they're all standard brightness though.
But I can't help thinking that cheap headlight bulbs = those morons who keep dazzling me
1985 BX 19 GT
2007 Alfa Romeo GT
2007 Alfa Romeo GT
Or HIDsMikeT wrote:I'm pretty sure they're the morons that have fitted illegal overpowered ones or somehow managed to fit the right ones but not squarely in the holder!Baldbazza wrote:But I can't help thinking that cheap headlight bulbs = those morons who keep dazzling me
1985 BX 19 GT
2007 Alfa Romeo GT
2007 Alfa Romeo GT
Regarding the "reach" of the headlights. Can the beam of the headlights be adjusted with the lampholder position or the like?
Given the car is self levelling, could my car be riding too high at the rear end? Would it be easier to adjust this than the beam height?
Am I thinking too much?
Should I take an aspirin & lie down in a darkened room?
Or leave the light on if the lampshade cuts out enough direct light?
FCF refugee
1998 Xantia 1.9TD Est Tempt 2
As far as I know, the lights have normal adjustments for aim, just as any car.cpt_spalding wrote:Regarding the "reach" of the headlights. Can the beam of the headlights be adjusted with the lampholder position or the like?
Mind you, it is very much worth checking the ride height as this will naturally have an effect. Adjusting the ride height to make the headlight aim right though is over thinking it a bit
You have to be careful playing with ride height, not only the safety aspect whilst doing it but also that it has a marked effect on the ride quality if it is not spot-on correct.
Jim
I was able to assess my MK I Xantia headlights again this evening for the first time in about 9 months and whilst not as good as MK II lights, with the Philips Vision bulbs, they are more than adequate.
The main problem with them appears to me to be a poorly defined dipped beam compared to MK II lights.
The worst problem though is driving against HIDs and maljusted headlights, of which there seem to be rather a lot about around here. One particularly bad example was a chavved-up car of indeterminate identity that looked as if it had after-market HIDs fitted
Jim
I got a pair of "extra white, blue tint" bulbs today - claims to be colour temperature of 7200 and they certainly make a difference - but I'm now sure my aim is too low.
I think the same about oncoming traffic, they seem to be getting worse! There were many cars out tonight on the unli A35 with one failed dipped beam compensated by fog lights instead! The other troublesome oncomers appeared to have patterns that scatter the countryside. Then there's those that just drive with full beam regardless. As for HIDs, they're just blatantly illegal coverage, surely?
98 Xant 1.9TD fuelled on veg
93 Granny SORN
90 VFR750 Breaking
93 Granny SORN
90 VFR750 Breaking
Hmm.
I like HID's. When I had a co. car & had to replace the Audi A4 (appalling headlights, then) I got a Passat & demanded HID's. They were excellent.
I'm sure the beams were self levelling (rather than the whole car) & I don't recall any oncoming vehicles flashing me (out of irritation etc).
FCF refugee
