pipe flaring tool EBAY
http://cgi.ebay.co.uk/Citroen-Flaring-T ... 3a62625191
With pipe
http://cgi.ebay.co.uk/Citroen-Hydraulic ... 3a62627fa3
With pipe
Linegeist
messerschmitt owner
they are about £65-70 new aren't they?Defender110 wrote:I think it's gone past it's worth already?
I would have thought that one hour of use would recoup the cost of one over the hassle of getting a dead, arse on the floor Citroen to a garage.
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
Linegeist
messerschmitt owner
that's true - but, I would reckon the important part (the part you don't want damaged) is the actual part that flares out - the damage I see is on the threaded area and as long as you can fit the bolt in and clamp it all down straight, it should be fine.Linegeist wrote:The problem is, its condition is a bit suspect. If it was "as new" then I'd go to £40 like a shot - but it apparently isn't, so could quite feasibly be knackered on receipt.
I have a perfect 3.5mm one here but would fancy a 4.5mm tool too!
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
Stinkwheel
My issue is its 4.5mm. Not very many 4.5mm pipes (certainly not like the numerous 3.5mm ones)
so its not worth a huge amount cos of that really.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- BXpat
- BXpat
Brian
Stinkwheel
On the old CX mailing list many of the scandinavian countries members had made their own flaring tools, i will have a look later see if any of the info still exsists on their site.
Having said that as mentioned about abpprox 70 quid will buy you one from plaedies.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- BXpat
I reckon we'll all soon be at it - making pipes or getting others to do it for us.
At the moment many of the important pipes are available still from Citroen but gradually holes start appearing - like the oddities of one brake pipe being available and not the other side!
Wasn't there some bloke in France selling the whole kits on Ebay? They weren't cheap - €200?- but everything was in there I think to get you merrily piping away.
- x 27
Nat
pliedes aren't selling the tools anymore, I phoned up after one last week and they'd stopped selling them unfortunatly, I found another place on the web that sold the tool for £100 for the 3.5mm but then you had to pay a further £45 for the 4.5mm adapter if you wanted it, same again for the 6.35mm adapter too.
http://www.automec.co.uk/oakes_tools/oa ... e_set.html
1991 BX 4X4 GTI back on the road
