Pipe and Connectors supplier?
hvanman
Post by hvanman »
Hi, I am going to need to splice in some new high pressure pipe, but now that pleiades is no longer around, could anyone suggest a good source for male connectors, female joiners and a length of 3.5mm pipe?
Thanks, Simon
x 174
As far as I know Pleiades they are still going
01487 831239.
hvanman
Post by hvanman »
Thanks Kevan, sadly I can't see any 3.5mm products on their web site that could be used to joint the existing pipes...
hvanman
Post by hvanman »
Roverman wrote:As far as I know Pleiades they are still going
01487 831239.
Thanks, I will try them tomorrow, but found this on the web:-
http://www.geolocation.ws/v/W/4d76bc658 ... ent-the/en
x 174
I tried the number, it rang out....
NeilGP
Post by NeilGP »
They are open, I bought a reconditioned/exchange brake valve from them a couple of weeks ago.
Neil
A476 RBX
Series 1 BX 16TRS
hvanman
Post by hvanman »
Great, Thanks Neil, I will try them tomorrow, would be a pity if they were no longer around, but they don't make it easy for people to buy from them with no web site etc..
they dont make it easy to buy from them when they do answer the phone I find..
they actualy just moved premises a while ago, i think that was when people were haveing trouble contacting them/Martin,
as i have never had any probs and found there service second to non,
I'm sure the 1/8 (3.2mm) or the 4mm nylon tube would easily do with the tollerances in the connectors.
hvanman
Post by hvanman »
This is for the high pressure system, is nylon suitable?
KevR
Post by KevR »
hvanman wrote:This is for the high pressure system, is nylon suitable?
No!
Well it's what is used for all the very high pressure air brake systems on all HGV trucks and coaches and I've never had one burst, rub through yes but burst no!
''Suitable for lube, air & fuel line''.
W.P. = working pressure.
OD, ID, W.P. OD, ID, W.P.
4mm 2.5mm 26 bar (377 PSI) 1/8" 0.058" 43 bar (623.5 PSI)
KevR
Post by KevR »
Yebbut, isn't a Cit suspension system working at about 15 times the pressure of an HGV air brake system...?
