Creamy oil.
bexxy
Creamy oil.
Hello to all, wondered if anyone can help I checked the oil today on my BX16TGS auto and seen that it was just short of max so i went to put a drop in and when i took the filler cap off there was a lot of creamy mayonaise in side the tube, cap and when i took the pipe's off the cap they had some in aswell, I checked the radiator level which was just at the bottom of the tube when you look down which is the same level as when i bought her in november , I know that the mayonaise is caused by water/moisture in the oil but that is about all i do know i have been told it could be the head gasket but she drive's fine run's ok . I did notice a bit of water from the exhaust when started and left to warm up but just thought that it was condensation , the car only get's started and used once a fortnight as i work away at the moment but give her a 20-30 mile run.thank's in advance for any help..mark ( bexxy).
2010 Berlingo 1.6 hdi (15000 miles
2009 107 silver 5dr (9k)
2006 C15 Rouge , windows all round (27k )
3 Honda C90 cubs ( 24miles, 400miles, 10k)
2010 Suzuki van van 125 (172 miles )
Raleigh Bomber pushbike
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
That sounds normal really for a car used on short journeys infrequently. You'd do well to clean all the mayonaise out the filler cap and breather pipe work. If you do short journeys it'll keep reappearing but it's only water vapour condensing and emulsifying with oil vapours.
Water out the exhaust is normal too at least until the car is warm and you've had a good 30 minute run. Keep an eye on the coolant level all the same.
bexxy
Cheers hope your right , i've just dipped the coolant using a thin piece of cloth and it came out all brown and slimy , think it all need's replacing and i will run a flush through the engine then drop the oil and put new in and a filter, i've cleaned the cap took the gauze out which has been out before looking at the state of the cap on the inside and cleaned in petrol and put back together. All in all i think she just need's to get out more..
mark(bexxy)
mark(bexxy)
DavidRutherford
- BX Digit man!
- x 25
- x 25
There shouldn't be any problem with the engine and box David... it's the cosseted 16TGS Auto I picked up with 23k miles and a thorough main dealer history, and it's still on less than 40k I think. It was tight as a drum. Sure it's still in good order.
bexxy
Still only on 39600 mile's phil and drive's great it's just me nit picking i like everything to be right. I noticed the cambelt was replaced in feb 2004 will that need done again as it's been 5 year's and a lot of car's state a set mileage or 5 year's.mark(bexxy)
- x 25
bexxy
- x 113
On the mayonnaise - the colder the temperature the more condensation will occur.
I believe some people wrap insulation round the filler and oil breather pipes.
My GTi lives in cold temps every winter. Since removing the gauze permanently in the filler cap I do not see any mayo in th pipes.
bexxy
- x 25
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
prm
The gauze should act as a oil mist/air separator for crankcase/sump ventilation.
By restricting the air flow, any oil mist present should collect on the fine mesh and then return any surplus oil. Also, when interlinked to the intake system, this air flow should??, remove the water mist content.
With a cold engine, water vapour/condensation collects on the wire stands initially, restricting the return of any oil, thus emulsified oil mixture builds up until sufficient temperature is achieved to dissipate any water.
Would recommend removing pipe and cap and soaking in paraffin, you will be amazed by the amount of crud that can build up in vent pipes, especially if they are slightly collapsed internally or kinked.
You could try a slightly higher temp thermostat (this weather!!) for continuous short journeys, oil change??
Found a particular brand/grade of oil seems to suit individual engines, with virtually no crud build-up hot or cold.
