TZD Turbo on Auto Trader
Hurricane
- x 3
K BX 19 TXD
J BX TZD Turbo Hurricane
J BX TZD Turbo
J BX TZD Turbo
RichardW
Tourist
- x 94
Tourist
I presumed it had the 3 spoke for 1992 and 1993 seeing as the TXD does, and the TZD is higher spec. If I'm not mistaken the 3 spoke was originally used as the "sporty" wheel (quite similar to that used in the ZX Volcane) and was later used as standard on TX and TZ models.
I might be wrong ...
That car looks silver to me too but it's listed as grey. If someone on here buys it be sure to post about it.
Both of my K platers have the multi spoke, only my H reg gti has the single spoke. I think i prefer the single spoke, makes it feel & look like a proper citroen.....
I'd like to prefer the single spoke, for the same reason. But I found that with the single spoke (on my K plate estate) that my hands had to grip the wheel that little bit tighter, and caused slight ache on long journeys. I like to have something to rest my thumbs on!MULLEY wrote:I think i prefer the single spoke, makes it feel & look like a proper citroen.....
(If anybody wants a good single spoke wheel I have one - available for a BXagon donation.)
Boxwolf
Went to see this one today, report here: http://bxclub.co.uk/forum/viewtopic.php?t=10082
Yes, it certainly does!RichardW wrote:[spotter mode on]
It appears to have A/C!
[/spotter mode off]
Someone get it bought.
However Boxwolf, if the aircon is working that could be it's clutch you are hearing clicking in and out and the drips could be condensate from the system.
Boxwolf
I didnt see the drips for myself, my dad reported something black had dripped down. Does the aircon clutch sound just like the hydro pump? it seemed to make a couple different noises but the one I was listening for was the 'chirp' made by the pump. It is possible, if the aircon clutch makes a very similar noise, I could have mistaken itWay2go wrote: Boxwolf, if the aircon is working that could be it's clutch you are hearing clicking in and out and the drips could be condensate from the system.
... and walked away from a near perfect bx?
Boxwolf
Tourist
Boxwolf
