knocking
BX nut
knocking
Hi. I have a knocking noise when going over bumps. This is coming from the front end somewhere. I have replaced the link bars on both sides but it still continues. Any further ideas would be much appreciated.
kiwi
- x 4
BX nut
BX nut
vortex
I was going to suggest ball joint(s) once you'd elminated the subframe bolts.
Over here they're called anti roll bar drop links, and he's already replaced these I think (if that's what he means by link bars?) That would have been my first thought too! Does it do it if you come on and off the throttle? If not that would tend to rule out engine mounts.vortex wrote:i don't know how to call them, but i think these rods.![]()
Aerodynamica
Correct me if I'm wrong but the subframe bolts coming loose only gives a knocking under braking and standing starts as the torque pushes the subframe back or forward.
(unless it's really loose that is!
Mine had a single bolt loose - the one below the driver's heels - dead easy to tighten - need to lift up the carpet on that side.
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
- x 115
kermit the frog
I would tend towards what Jaba says.
I have had this wild goose chase myself and that ended as a swivel loose and worn.
I have also had the subframe bolt problem.
Regards Kermit
Regards Kermit
vortex
Thanks for the explanation.mat_fenwick wrote:Over here they're called anti roll bar drop links, and he's already replaced these I think (if that's what he means by link bars?) That would have been my first thought too! Does it do it if you come on and off the throttle? If not that would tend to rule out engine mounts.vortex wrote:i don't know how to call them, but i think these rods.![]()
I also have a light knocking on bad roads, but doesn't disturb me.
Just put a crowbar between diffent joints and bolted sections and see if you can find anything.
Also put the car in the lowest position, otherwise you won't feel anything. If you have the car in ride-height of highest position, all joint will be compressed and no movement will be detected
kiwi
- x 4
Re: knocking
BX nut wrote:Hi. I have a knocking noise when going over bumps. This is coming from the front end somewhere.
Have you accidentally trapped your mechanic under there? He might be wanting to get out?
