Hello Team and I am a BX newby with a problem
Ian Stanbury
My cam belt has broken on my petrol engined Athena and I wonder if anyone can tell me, if with that engine, there is a chance that I will have damaged all the pistons or not - It came to a grinding halt on a country road whilst going along at 30mph - Any advice will be gratefully received
Thanks - Ian
Thanks - Ian
electrokid
I don't know about the Citroën engine but the general rule is the slower the engine was turning when it let go the better chance you have of fixing it. Last winter 2 people I know had Astras throw the cambelt - one just got rid of the car - the other (the slower of the 2 drivers) had it fixed for about £450. At 30mph I'd figure it was worth having a look.
Good luck with it - let us know how it goes - I'm sure others will have better knowledge of the subject.
I'd agree that it may be worth a look.
A mate of mine had a Pug 405 GTi which was doing at least 30 when the belt went. He borrowed my BX manual and fitted a new belt on the basis that he didn't have much to lose and when he fired it up afterwards it ran as sweet as anything!
Very unlikely to have damaged the pistons.
Maybe bruised them, but they'll no doubt carry on, you'd have to be the unluckiest man alive to have smacked a hole through them.
The valves on t'other hand will almost certainly be bent, 4 at least I'd have thought.
I'm guessing this is a 1.6 XU5?
You might have been really unlucky and smashed the cam aswell though..
the AUTODATA cam belt book states "DAMAGE YES",
but i have fitted a new cam belt to a couple of petrol BX's over the years and they ran seemingly fine,
what can happen is you just lightly clip the valves, then after the new belt is fitted and seems to be fine it burns valves out as they could be very slightly bent, but not enough to notice at first, well at least not without a compresion test
Gibbo2286
Sadly Docs correct, the valves will very likely be bent, it happened to me on a Xantia 1.8 8v which is basically the same engine bored out and 4 of the valves were knackered.
However as its a carb fed car its not a bad job, unless someone on here has a complete cylinder head they can sell you I would invest on getting the old one rebuilt as you may find it runs better when its all done, mine did.
Remember to get new studs/nuts and cambelt tensioner
Ian Stanbury
Thank you all so much Team
..And of course I meant valve damage and not piston damage but I will investigate and will report back..
Thanks again everyone
On my Xantia there is alot more pipes and wires than on the carb fed BX so in my opinion wouldmake life a bit easier.mat_fenwick wrote:I think it's an XU7 for what it's worth...
I'm puzzled by the bit about it being carb fed meaning it's not a bad job - I've not done the head on a Xantia but why does the injection system make it much more difficult?
As far as I know the 1769cc Xantia 8v petrol engine is a similar unit to the the BX 1.6/1.9 engine.
Gibbo2286
