Quad Lamps
richardd1652
Quad Lamps
Post by richardd1652 »
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
Christ - that's almost what I paid for the car :shock:
Mind you - they would be easier to bring back than that early estate....
Post by Mothman »
Nice but pricey. Would they fit any BX?
Yes. Straight swap I believe.
Post by Mothman »
Excellent Phil, they would look good on the old Estate but a tad expensive. Think i will save the dosh for more beer.
kermit the frog
Post by kermit the frog »
Yes definately a straight swap if you look at the rear picture you can see where they clip onto the existing adjusters.
Have you noted that both headlights take H4 bulbs thats double the light on dip and main beam.
Now that would give Mike E a run at the national lighting contest.
(Phil, on that note, I need to get those 2 Hellas on the front of the BX lol!)
Mind you I reckon this would give Mike a run for his money too...
They will have LHD lenses in so no good for UK???
Turn them upside down? :D
Philip Chidlow wrote:Turn them upside down? :D
It is a plan but it does have flaws! :wink: :lol:
But surely if you turned them upside down they'd become ceilings :?: :roll: :wink:
kermit the frog
A very valid point about them being LHD
And Phil turning them upside down wouldn't work as they would indeed be lighting up the sky.
Pity though.
Just joking :lol: :wink:
rayfenwick
Post by rayfenwick »
Surely the spots aren't handed - ie: have an even light distribution left and right?
Ray
www.citroencarclub.co.uk
kermit the frog
These are not spot lights they are a direct replacement headlight conversion and so have a beam pattern lens and the bulb fitting is biased to the wrong side.
