1986 19RD Break
List of jobs completed is sounding good, I notice the essential mechanic's tool by your right foot!
Ah yes - well spotted Mat, as Peter Gabriel sang : Sledge.. sledgehammer. Nemesis of balljoints and bearing shells, and good therapy.
I got the steering rack out today to replace the tie-rod assemblies. The rubber flexible steering joint had split too so replaced that with a good used one.
Then, while I had some space I tackled the lower speedo cable which broke a while ago. That rubber 'thing' that locks it into the drive has to be one of Citroen's strangest ideas, especially after 25 years. I had to take the whole drive out and bash the rubber thing out. Cable replaced with one that I found hanging off a 16v gearbox - rubber thing on that came out easily as intended by the tea-boy that dreamed it up. Looking forward to seeing the yellow drum revolving again!
Edit : just looking on Service Citroen I see that 'the rubber thing' is still available : 265007 'stop pin' ( just in case anyone's interested!). They refer to the speedo cable as a 'counter hose!'
x 141
Well done Todd, keep it up.
Today I got it running for the first time since November then I bled the front brakes.. no problem.
Moved onto the rear brakes and the doseur. I was at the rear tightening up the bleeds on the calipers when I saw LHM spraying out at the front. The bleed on the doseur was pissing it out at a great rate, I think by the time I de-pressurised and switched off it must have pumped out 2 litres of new LHM and the bleed valve was closed!
I was cursing the day that I ever started fiddling with hydraulic Citroens and was wondering what mistake I could have made with the doseur re-build while considering a greened engine bay and huge puddle beneath.
It is a new bleed valve that I bought from Citroen so I took it out to inspect. Looked fine but then I decided to see if I could find the old one..
Emptied the bin on the floor which was completely full of months' of car repair crap and unbelievably there in the bottom in a black sludge was the rusty old valve, with a pointed end on it, whereas the new - generic - bollox from Citroen was flat. Could this be it?
I wire brushed it clean then put it in and pressurised.. not a drop. The pointed end was crucial for the seal. I was cursing those morons who sold me that valve specifically for a 2-slide doseur. Thankfully I found the old one otherwise I would have scratched my head off trying to work that out!
Must check in future that new parts are identical.
My first green fountain! :roll:
rayfenwick
Post by rayfenwick »
toddao wrote:My first green fountain! :roll:
...probably won't be your last... :?
Ray
www.citroencarclub.co.uk
There were four others today.. how about I fitted two seals to each of the front spheres sometime in sub-zero January for some odd reason so they had a nice squirt too. I'm going to get a 500 litre drum of LHM.
maxgreenwood
Post by maxgreenwood »
green fountain
A good name for an ecologically love bent musical collective?
'90 16TZS (m), White, 86k
Or a caravan park. I was looking to see if there was a band called 'Green Fountain'. :D
maxgreenwood
nice!
you have been googled.
It's now got two years' TÜV (MOT) - hooray! I'm just having a small beer to celebrate but here's a couple of pics of the ole girl back on the highway..
( more pics/details to follow)
Wonderful. The hard work pays off! Looks splendid. Much envy.
Nice one! Have an extra beer for me...
Utterly droolingly lovely. Well done
Post by ken newbold »
Yeaaaaah! still love the number plate :D
maxgreenwood
Fabulous. :D Good work!
