STOP Light
richardd1652
STOP Light
Checked all the levels like coolant,hydraulic,oil, its pumping up properly etc but still "STOP" illuminated but nothing more. Any ideas anyone as im at a loss with it?
When started ,battery light,hydraulic light etc go out but just "Stop" stays lit.
Richard.
Richard.
maxgreenwood
must be an electrical connection or a stuck sensor? I've heard of the LHM res float becoming stuck before but it sounds like that is working.
'90 16TZS (m), White, 86k
richardd1652
maxgreenwood
it's a bit beyond my expertise, i don't know how those sensors are wired up. hopefully someone else can suggest something to try. Good luck.
is that your Red 14RE on the bay? Looks nice.
richardd1652
Linegeist
My understanding is that the BIG RED LIGHT is a multi purpose idiot lamp designed for dense Frenchmen who don't do subtle flickery-gaugey stuff.
This lamp is wired up to low water, overheating as well as low lhm ........ so any one of those sensors could have filed - or indeed a wire become trapped and completing the circuit.
My first port of call would be to disconnect each sensor in turn to see if the lamp goes out. If not, then there's a fault in the cabling.
Normally there should be another warning light on to indicate what area of concern it relates to, don't suppose a bulb might be out hence why you've only got the one stop light on? When my lhm was low as it was pissing out, there was another red light on as well, hence why i mentioned it.
BX DIY wrote:There are a few diodes in the instrument panel operating the STOP light so that it comes on simultaneously with any of the major warning lights. Should one of these diodes become shorted, one warning light (eg. low LHM level) can trigger another one (coolant level) erroneously. The easiest way to check this would be to short the coolant level and LHM level sensors one by one to observe whether any of them triggers a second light, too. The oil pressure switch, on the other hand, is supposed to light up everything else: this is what happens when you turn on the ignition but do not start the car yet.
The diodes are very cheap from a common electronics store, a few eurocents each, so you could renew all of them while you're at it.
rayfenwick
My CX 22TRS has a "check" button which lights all the warning lights when pressed. Maybe not a bad idea for a BX either - shouldn't be too difficult to fit (he says, now realising I've volunteered myself to experiment).
Ray
www.citroencarclub.co.uk
- x 27
rayfenwick
Was there a warning light to tell you that the warning light warning of other warning light failures had failed?
Ray
- x 27
rayfenwick
Ah...so was there a warning light to warn you that the buzzer warning that the warning light warning of other warning light failures had failed, or was that a buzzer too?
Ray
- x 27
