messerschmitt owner
Ian, I couldn't agree more, but to get it to an MOT state, you could forgo them and refit them later. I certainly wouldn't advocate breaking of the law when carrying passengers, but it is a neat trick to get it MOT'd, when you can find belts at your leisure.Dollywobbler wrote:Thanks Richard. PM replied.
I want the seatbelts to be there really. 1986 is the cut-off as my 2CV is the same age, and must have the belts.
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
We'll see. If I can get belts, I'll fit belts.
Just had it running as I wanted to run it up to temperature - though I'm having to use my thermo-equipped multimeter to tell me how hot things are. Worrying at first as the engine was hot, but rad and heater were both cold - easily sorted by removing the huge nut on the thermostat and letting all of the air out! Not had it hot enough to get the fans running (surprisingly difficult on a 19 diesel, even with a knackered rad) but certainly able to get it warm - temp reading of about 75 degrees through the bleed hole (if that's what it is) and cooler than that in the rad - as you'd hope.
Heater got nice and hot - which is nice - but the ol' resistor pack issue is clearly present. Fan only works on position 3.
Still need a battery. The one fitted to it won't hold any charge at all. Roll on pay day!
No resistor pack in the Mk1
however, depending on date of manufacture, it could have a completely different fan on board
Some of the early Mk1's have a fan that sits well down inside the car, behind everything else
the good news is that it might just be stuck and it can be seen and prodded (just) from the scuttle under the windscreen.
I've just had the tailgate fully open for the first time, and re-fitted the gas strut on the RH side. Then discovered why it had been removed - the RH hinge is completely busted! Then had to try and remove the strut while holding the very heavy tailgate open. Phew.
It would be very useful at this stage if someone could post up some pics of what the hinge SHOULD look like. At the moment, I'm not sure if the damage is to the tailgate itself or the body. Bit of a set-back this, as I think a non-opening tailgate is a reason to refuse a test from the tester's point of view.
I'm quite happy to be corrected, but I don't think a non opening tailgate is an MOT failure, as it's not required for passenger exit. On the other hand, a broken hinge would probably be classed as unsecure bodywork if the tester noticed it.
We'll see if the resident MOT tester on Autoshite can confirm! It's certainly a set-back. I know this thing's got bodywork issues, but I was hoping I could get it on the road before sorting them. The other issue is the rear bumper sticking out from the dented rear wing. Was going to see if the test station (who do a lot of rally car prep) could try and pull the wing out a bit...
Tailgate does need to open for an MOT. However, on the positive side, catsinthewelder of this parish kindly send me some pics of the hinges on his estate, which has enabled me to confirm that it's the tailgate that's broken, not the body part of the hinge (RH, LH is still out of alignment). I class that as good news.
New radiator has been fitted today. An easy job, though I've got no coolant knocking about, so job completion is on hold! Also, got a nice digital temp gauge, but the 'universal' sensor is certainly not going to fit the BX. Presume having it screwed into the 'stat' housing would be the most ideal solution? Diagram that came with it suggested hacking into the top hose - but surely that'll only show a reading once the 'stat is open? Not what I want.
I guess I could try and replace the gauge sensor - do I really need an overheat sensor if I've got a gauge showing the reading? I see there are two sensors just behind the 'stat housing. Guess one of those is for low coolant?
Still need a battery, but still waiting for pay day...
That radiator looks like the sink from my 1st flat.
