Gti throttle profile
maxgreenwood
Post by maxgreenwood »
I noticed the GTi's throttle has two alternative throttle cable grooves slightly different in shape, which I rightly guessed would change throttle response: I discovered the cable can be moved over and because the shape is different the throttle opens quicker when depressing the pedal which I think is better.
The question is, does anything else need to be changed along with this, I think throttle opening controls everything else in the engine management? Ie. there is no accelerator pedal sensor to take into account or anything?
'90 16TZS (m), White, 86k
x 115
Could the unused one be for the auto throttle kick down cable?
maxgreenwood
That hadn't occurred to me but yes, maybe, thinking about my old xm. Anyway I prefer the throttle response with it moved across. Kicks in with less pedal movement. I hope it's ok to drive like that. Dropping by the garage tomorrow so I'll get the low down.
