stuart_hedges wrote:What doesn't work on yours?
I need to buy a new pressure cap 'cos the seal on mine is definitely knackered as I discovered the other day. Suspect thermostat may also be gorn (no overheating, no power loss, water loss a bit random/minimal, no water in oil, so it had better [expletive deleted] not be the [expletive deleted] head gasket as it was only -expensively - done in 2007). Also had advisories on brake flexi-hoses and injector washers at last MOT (Jun 11). May need a couple new tyres as well.
So it's a bit marginal ... I really don't wanna spend any
more money on it, but it's too good to scrap*, fairly low mileage, few minor cosmetics but otherwise reasonably tidy for 11 year old car and everything else is OK, I've kept it regularly serviced. Soul searching ... I just want easy life/fast sale pref for over scrap value (£500 would do nicely), work is just insane atm and I haven't got time to [expletive deleted] about on e-bay.
*assuming it's not head gasket in which case [expletive deleted] it, it's going over the bridge.
/rant ... ah, that's better
The air con, BTW,
does work. Mostly.
