ABS Flexi Hoses
Easy Peasy, but who has a M9 tap in their tool box?..
Easy cheap option:
http://www.ebay.co.uk/itm/CITROEN-BX-FR ... 9220304063
Easy cheap option:
- Vanny
BX 16v Ph2 - XPO - x 79
Cheers Mat, i was going to look to getting some braided stainless made up, but i wanted to get a proper ABS pipe to model it off. Funny enough of the pipes i have in stock, there all M8. Irritating as at least one was sold to me as ABS compatible!!
PS i have an M9x1.25 DIE, but not a tap. Not the foggiest why i have it, but i did buy it for something specific.
- smiffy1071
- pies are evil!
A.B.S Flexi-Hoses.
Dear All.
I just wanted to thank everyone for their kind assistance, in helping
me to locate some front ABS flexi-hoses, My ever so kind
chaps at my not so local factors can supply me with some, no problem,
aswell as two handbrake cables, and some rear tailgate struts, as my
tailgate doesn,t seem to lift very much at all, if I press the button, the
tailgate stays where it is no lift on them at all, I have to really lift
the tailgate up to get it started, before it starts to raise itself, but it is
quite a struggle for me.
Many Thanks Again.
Vince.
Many Thanks Again.
Vince.
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
Re: ABS Flexi Hoses
Memory is crap nowadays but isn't there a difference in the diameter of the steel pipe as well, something like 4mm.?? As opposed to 3mm.
G.
G.
1991 BX 1-7 td Auto.
NEVER WRONG.
NEVER WRONG.
Re: ABS Flexi Hoses
Yup, 4.5mm instead of 3.5mm. I guess the larger diameter needed was down to requiring a faster response when the ABS system modulates the pressure.
Re: ABS Flexi Hoses
Just been to ' Brakes International ' in Rochdale , Lancs .. Tel no 01706 666999 for a new caliper and asked for a front brake hose also.
' Does it have abs as I have TWO hoses in stock but none of the others '
They are on ebay but can't remember the trading title.
Land Rover Discovery TD5
- smiffy1071
- pies are evil!
Re: ABS Flexi Hoses
I just tapped into google the part number from the Corteco bag that my hoses came in, and I found a cross reference chart.
Analogous \ Similar Parts of CORTECO 19018449
Manufacturer Number Description
A.B.S. SL 3423 Brake Hose
ABE C86136ABE Brake Hose
ATE 24.5120-0435.3 Brake Hose
BREMBO T 61 058 Brake Hose
CEF 511695 Brake Hose
CITROEN 95632790 Brake Hose
DELPHI LH6015 Brake Hose
FENOX PH213509 Brake Hose
FENOX PH212819 Brake Hose
FERODO FHY2260 Brake Hose
FIRST LINE FBH6057 Brake Hose
GIRLING 9002451 Brake Hose
HP BH05790 Brake Hose
KAGER 38-0119 Brake Hose
KAWE 511695 Brake Hose
LPR 6T46847 Brake Hose
MAGNETI MARELLI 440019018449 Brake Hose
MALO 8029 Brake Hose
MAPCO 3781 Brake Hose
OE 95632790 Brake Hose
ORIGINAL IMPERIUM 23279 Brake Hose
PEUGEOT 95632790 Brake Hose
REMKAFLEX 2286 Brake Hose
SASIC SBH0137 Brake Hose
SPIDAN 39526 Brake Hose
TRISCAN 8150 38102 Brake Hose
TRISCAN 8150 38105 Brake Hose
TRW PHB451 Brake Hose
I'm sure that with this many part numbers and manufacturers, it shouldn't be too hard to find some in stock...
Re: ABS Flexi Hoses
Name?PEUGEOT Brake Hose
img?
Length [mm]?470
Port Thread?M - F
Thread Pitch 1 [mm]?1
Thread Pitch 2 [mm]?1,25
Inner Diameter 1 [mm]?10
Inner Diameter 2 [mm]?8
http://www.autopartoo.com/oem/38609.html" onclick="window.open(this.href);return false;
img?
Length [mm]?470
Port Thread?M - F
