valve clearances
barry badger
valve clearances
I've removed the cylinder head from the 4x4 and had it overhauled at a local head shop with the brief to do whatever it needed. They rang me to say it just needed the exhaust valves and guides replacing, stem oil seals and a light skim, the inlets were fine. I got the head back, the bill was £55 less than I was originally quoted because the inlets didn't need doing. On checking the head I found that the inlet valve clearances were between .28mm and .30mm. According to my 2010 autodata the inlet valve clearances for a d2f engine should be between .15 to .20mm. I queried this with them and they said years ago citroen had released a bulletin to increase the inlet valve clearances because of a problem with burning out inlet valves. I'm not convinced. I know it will run fine with these clearances but I want it as perfect as it can be. Has anyone heard of this increase in clearance size?
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
barry badger
Incidentally they have set the exhaust clearances to .35mm which is at the bottom end of the .35 to .40mm clearance autodata lists, which conflicts with the increased inlet clearances.
barry badger
BX 16v Ph2 - XPO - x 103
barry badger
2013 Nissan Leaf Acenta 24Kw - x 197
I've found;
BX 19 TGS, TRS/TZS, 1905 cc, 1991-92, Engine Code D2F (XU92C+)
Valve clearance - inlet: 0.15-0.20 c mm (cold)
Valve clearance - exhaust: 0.35-0.40 c mm (cold)
or;
BX 19, 4x4, 1905 cc, 1989-90, Engine Code D2E (XU92C+)
Valve clearance - inlet: 0.15-0.25 c mm (cold)
Valve clearance - exhaust: 0.35-0.45 c mm (cold)
or;
BX 19i, +4x4, 1905 cc, 1988-92, Engine Code DDZ (XU9M)
from a fab website http://freespace.virgin.net/carmechanic ... itroen.htm
or;
or;
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
