rear hatch in green needed...
themildbunch
Post by themildbunch »
Seems rear hatch problems are common this week!
My shed's one had been fixed at some point with lashings of epoxy and finally let go today:
Anyone got one for a saloon in green?
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Re: rear hatch in green needed...
:shock: That's the strut mounting isn't it? I had the joint give way on a Montego estate once and the strut went through the window, so it may have been a lucky escape there!
rabbercelt
Post by rabbercelt »
got one in red-if that's any use.
themildbunch
rabbercelt wrote:got one in red-if that's any use.
Hi Graeme
It may well be if I can't repair it any better than it was before... Better ad it to my shopping list with you!
1988 BX 19 Gti 16v
rabbercelt
green and red -nice combination!celtic motor!
themildbunch
Yeah!
Could be on my way to a BX version of this:
1988 BX 19 Gti 16v
smiffy1071
pies are evil!
Post by smiffy1071 »
or I might have one for you in the correct colour if you still need it...
Let me know as I've not yet taken it off the car.
Johns will be Nice and localish to
themildbunch
smiffy1071 wrote:or I might have one for you in the correct colour if you still need it...
Oh, that would be great - the broken section of the hatch was lost somewhere near Asda Bedminster by my son so a replacement hatch is the only option now!
1988 BX 19 Gti 16v
I would have thought some sort of repair would have been easier, a new screwed on bracket out of a little angle aluminium or similar? It would be a shame to write off a tail gate because of one little bracket?
smiffy1071
pies are evil!
When are you available, as changing the hatch is a simple, but time consuming job... takes ages to thread all the wires through!
I have tuesday or wednesday daytime or evening free if that suits...
themildbunch
Defender110 wrote:I would have thought some sort of repair would have been easier, a new screwed on bracket out of a little angle aluminium or similar? It would be a shame to write off a tail gate because of one little bracket?
I'm not sure if this is easier - I know it would seem a bit much to dump this hatch - but I'll hopefully keep it if I do replace it... I remember replacing one years ago on a GTi after someone stuck a broom through the glass! Pretty easy but was time consuming.
I'm not sure screwing into the plastic / fibreglass of the hatch is made of is going to be that strong. The catch on my estate hatch has threaded steel female things set into the material rather than bolts directly into the plastic, even then they are stressed parts that often crack over time, especially when the bolts get a little loose.
1988 BX 19 Gti 16v
themildbunch
smiffy1071 wrote:When are you available, as changing the hatch is a simple, but time consuming job... takes ages to thread all the wires through!
Hi - Wednesday daytime is good, Where abouts are you in Bristol? I'll PM you... thanks
1988 BX 19 Gti 16v
smiffy1071
pies are evil!
themildbunch wrote:Hi - Wednesday daytime is good, Where abouts are you in Bristol? I'll PM you... thanks
PM sent!!
pretty sure I saw this car on the Cumberland Basin being driven by I assume Mrs. Mildbunch back end of last week maybe? Looked nice, thought it was my Dad for a moment, so apols if Mrs. Mildbunch mentioned a mad bus driver flashing lights and waving like a loon!
