Strut return pipes
Strut return pipes
Ok, I don't want to fit any ol' rubbish. Where's the best place to buy some good ones? Preferably someone who delivers quickly as the car is on stands in the garage.
Re: Strut return pipes
AEP do genuine Citroen parts if you can't get to a dealer.
Post by citronut »
Ian
here is price and part No.'s for the leg pipe and clip from citroen if still available
95622818 LEAK BACK HOSE 11.61 GBP 13.93 GBP 13.93 GBP
96127591 ADJUST COLLAR 4.38 GBP 5.26 GBP 5.26 GBP
here is price and part No.'s for the leg pipe and clip from Citroën if still available
As of a couple of weeks ago they were available - I bought one of each for Timex!
Richard (rxbx) had a set for sale at cxm
As repeated from your Gallery thread.. I highly recommend a pair of these 'Clic' pliers to make life much easier re this job..
smiffy1071
pies are evil!
Post by smiffy1071 »
/\ Yes, you absolutely MUST have a pair of pincer type pliers, or you'll find it impossible to close the snap ring around the strut.
I use something like these
which are cheap, and effective!
I must admit, last time I just used a cable tie (but kept the metal bracket). I have pliers like the above but with a slight overlap and I still couldn't get the clip on.
KevR
Post by KevR »
I usually use cable ties as well. Never had a problem
smiffy1071
pies are evil!
I used to use very wide zip-clips... until I was told to get some pincers!
