I guess in this sequence that Jury Rigging is to patch the split with duct tape, silicone and zip ties until you get home!JayW wrote:
Top radiator hose splits a couple of inches from the hose clip:
1. Repair properly: Replace the entire hose.
2. Bodge: Trim the split piece off, cut the hose in the centre and add a length of copper pipe to extend the hose to fit.
3. Botch: Trim the split piece off, stretch the hose to reach. Doing 70 on the motorway the hose tears off empties the water and cooks the engine.
The scrapper
BX 16v Ph2 - XPO - x 103
Re: The scrapper
Re: The scrapper
Vanny wrote:I guess in this sequence that Jury Rigging is to patch the split with duct tape, silicone and zip ties until you get home!JayW wrote:
Welcome back Vanny, hows married life?
Re: The scrapper
no no thats just semi temporary permanentVanny wrote: I guess in this sequence that Jury Rigging is to patch the split with duct tape, silicone and zip ties until you get home!
Wooscary
Re: The scrapper
Tim Leech wrote: Welcome back Vanny, hows married life?
These seemed to link together in my mind for some reason.citronut wrote: no no thats just semi temporary permanent
Martin
Re: The scrapper
What would these be classed as then?
Re: The scrapper
Umm - I've done a couple like that
Those who were on the Challenge will remember my self grip window winder handle on the GS, while I've used a Strongbow can as a get you home repair after the exhaust broke on an AZU I once owned. If you can find them, smooth sided food cans make a much longer lasting repair though - my parents used several on a Range Rover they once owned.
