BX 2.0 CT Turbo, it begins....
x 103
Re: BX 2.0 CT Turbo, it begins....
Tim Leech wrote:.I will need to fit the insert for a lambda probe though.
You can buy a weld on boss for not very much, drill hole, weld on. Just dont fit it onto the top of your pipe, the lambda sensor is normally 80mm or so long!
I have an exhaust for loan, PM sent.
Re: BX 2.0 CT Turbo!
MULLEY wrote:
Kitch wrote:Panel filter? Does fuck all for sound or performance. !
We'll have to test this theory on the rolling road day, i'll bring along a paper filter & we can then play :) If i get half a bhp i'll be pleased, haha...
We can if you want. I mean how likely is it that I've based my statement on experience?! :)
Tim Leech wrote:I will shortly be removing the Xantia HP pump
You might want to hang on to the HP pump, unless you've found a way of driving a BX pump on it?
Surely using the Xantia 6+2 and binning the woeful FDV is the way ahead?
Is that easy? not wanting to make it overly complicated.
Will the existing BX plumbing not be transferrable from one XU to XU?
x 103
Will the existing BX plumbing not be transferable from one XU to XU?
Read back a few pages . . .
Vanny wrote:
mat_fenwick wrote:
you can graft the Xantia LHM pump and pressure regulator system into a BX
Vanny would be the one to ask about that, as he did that several years ago IIRC.
Just need to adapt the BX steering rack to take a ~6mm feed. Fortunately most Xantia racks have a pointless adapter on the rack which gives you a starting point. Then just weld a ~3.5mm connector from a standard BX pipe onto the back of it. When i did the first one we just welded the hole lot up (with stick) and drilled a hole back through. You'll need the original Xantia pump to PAS pipe, which has several flexible sections (or make up a new pipe from scratch).
You cant (to my knowledge) fit a BX pump onto a CT engine, partly because there is no take off on the cam, and partly because I believe the ML cog box doesn't have the holes for the bolts.
I think i have the PAS adapter i commissioned Pleides to make up, if i can find it you can have it for the £30 i paid, but personally i preferred the 'weld an old connector to a new connector' method!
Am i being thick, i will be fitting a td bx gearbox and the hp pump will be driven from the bottom pulley not the cam as it is now on the 1.6.
is all the bracketry interchangable though? Not paid that much attention to CT lumps, but I'd have thought mounting the pump bracket may not be as easy as it sounds..
docchevron wrote:is all the bracketry interchangable though? Not paid that much attention to CT lumps, but I'd have thought mounting the pump bracket may not be as easy as it sounds..
Not sure Doc, was kinda hoping it may be!
Might be worth seeing how that v6 is being currently fitted to that valver in ireland?
MULLEY wrote:Might be worth seeing how that v6 is being currently fitted to that valver in ireland?
I imagine that will be a completely different Animal mulley.
Just a thought, will I need an oil cooler?
No idea as to whether its totally different or not, but some of it might be the same or at least it'll give you an idea of how much fabrication of the engine bay you'll need, just a thought.
If an oil cooler is fitted to the xantia then i'd say yes, otherwise i'd say no as usually with oil coolers they are fittted to highly tuned cars that are being used for racing or trackdays, neither of which i guess you'll be doing & i wouldn't call a 150bhp engine particularly tuned at 2 litres capacity.
..that_
Although many people worry about cooking the oil, you don't want to go too far the other way and over cool it, which would lead to high fuel consumption and wear.
If there's no oil cooler fitted and you have doubts, I'd look at fitting an oil temp guage, even if it's only temporary, so that you can monitor things until you have it all sorted.
hilarystone
My Cars: Citroen BX 16V, BX Van 16V, Visa GTI, CX Ambulance Turbo diesel, Xsara VTS Phase 1 and 2, Lotus Elan 1970, Clan Crusader, C8 2l petrol, 1982 GSA Pallas, 1974 GS Birotor
Post by hilarystone »
My experience with this engine in an Activa is that the oil stays really cool - the Activa has an oil temp gauge. It certainly runs cooler than my 16V and lots cooler than the Visa GTI's engine.
Hilary Stone
http://www.Hilarystone.com
Ok Hilary thanks, i wont be driving hard.
