http://www.ebay.co.uk/itm/Citroen-BX-19 ... 4172f940c7" onclick="window.open(this.href);return false;
Cheap banger for someone, those rear wings are a mess though!.
A good clean and a set of trims would help, sounds like the seller knows his stuff.
Tatty High Miles TXD Estate.
Re: Tatty High Miles TXD Estate.
Tim Leech wrote:.........
As it does look rather tired now (But hey, its done some mileage) !
Good luck to who ever buys 'L626 DOF'
You can bet with that mileage it was originally a fleet car and probably did half of them in the first 3 years I expect. As its a late one the bonnet steel and starting to rust!
Timex 2
jacksun1987
Another quite close one from me. Think that's 3 now in 2 weeks.
PAUL JACKSON
cosa 1.2 brezze 150 k had
2013 Nissan Leaf Acenta 24Kw - x 198
It does look like it's worked hard, almost bald tyres, rusty bits, rear arm bearings that made me go eeek! But if it's cheap enough, could be a reliable workhorse for someone once the niggles are done. Not sure if i've seen a TXD estate before either.
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
Tom have you never seen the one that 'Mr C' had ?saintjamesy89 wrote:It does look like it's worked hard, almost bald tyres, rusty bits, rear arm bearings that made me go eeek! But if it's cheap enough, could be a reliable workhorse for someone once the niggles are done. Not sure if i've seen a TXD estate before either.
Then there's this one which was sold recently IIRC (But can't find the F/S or Spot post) !
Also theres this one which I'm guessing will be a TXD as its got the later 'Citroen BX' font tailgate badge on it + side trims as a TXD ?
Click photos for forum links
Certainly not common, despite the few we've seen here. I can't recall ever seeing a TXD Turbo estate.
Afaik they didn't make at txd turbo estate.
Nah - it's far too straight to be Timex 2 - the wear and tear is only localised on this one, while on Timex it's everywhere!Timex 2
Sweet 16 (valve)
£231 it went for, and I wonder how many times that to get it up together?!
Or maybe it would be a breaker for parts for someone?
