BX estate hinge bushes
Discoil
Post by Discoil »
Might someone have or point me in the right direction for two hinge pins and also pin bushes for an estate car please .
Or would headlamp bush/fixing clips be modified to fit .
You should be able to tell I kinda need some real soon [-o<
Land Rover Discovery TD5
Re: BX estate hinge bushes
Post by citronut »
the hinge's on a BX do not have any bush's at all,
there used to be a guy near me that made up and fitted metal top hat bush's for cars, but i think he's gone off the rails now, and i dont think he wants to do work for anyone,
I may have some pins on a spare tailgate, but I'll have to check.
Post by citronut »
are we talking door or tailgate hinge pins here
Discoil
Post by Discoil »
citronut wrote:the hinge's on a BX do not have any bush's at all,
I should have also said that they are wanted for the tailgate .
I managed to move the the bushes round a bit and cut the ' squeak ' down by 50% .
The pins are a little worn and I will use shanked bolts if needed.
Part no. for the bushes is 95611494 according to Malcolm Lockwood !
