Hi,
Collected my BX14 Yesterday, having a few problems and was hoping to get some advice from the tech dudes!!
The car is over all a bit over soft and jarring taking corners, esp if road is rough. So assumed spheres are to blame. The car came with an Acc sphere to fix. So last nite I fitted this and seemed to get air in the system. Today was advised to put car up full height and losen release nut a few time, which seems to have sorted the suspension back to when I first drove it. Whist in the air I noticed a small leak around the rear ride height controller. Is this the problem? or just a new set of spheres ? or both!
Also I noticed the break pedal is virtually solid, mabey 1cm of travel. Is this normal? The breaks seem to work fine!
Any help appreciated dudes.
BX 14 RE Home
blobbyknobby
Re: BX 14 RE Home
usually unless someone has fitted the wrong spheres they dont normally become softer as the gas in them depletes,
but the ride does become harder,
the leaking height corrector is unlikely to be the cause either,
the N/C very very seldom give any trouble at all
the usual leaks on the H/C are either the short rubber pipe split/perished,
or the other rubbery bits perished,
the rubbery bits can be purchase from the likes of
http://shop.citroenclassics.co.uk/heigh ... -253-p.asp
jamescarruthers
- x 39
Re: BX 14 RE Home
Brake pedal has virtually no travel. You'll get used to it, so you can crash other cars by braking too late in them!
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
blobbyknobby
Re: BX 14 RE Home
Glad to hear the brakes are normal... lmfao
The speedo indication is very shaky is that normal too ?
Love the old school fuel indication, varys like nothing else!!
Re: BX 14 RE Home
Shaky speedo isn't normal, but is common. Try lubricating the cable, and check its routing. The cable route isn't ideal on RHD cars, so correct position is critical.
Stinkwheel
Re: BX 14 RE Home
This is the green car right? Is it not a BX14TE?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
