hyrdaulic rubber hose 3mm internal diameter 150mm long
nige
Post by nige »
Having problems trying to locate a rubber hose that fits to clear thin plastic hose. The main problem i have in locating it as i cant explain to any of the dealers where the hose is to locate a part! OK so its located by the front near side wheel, its a rubber hose of about 3mm internal diameter that fits into something on the subframe.. its about 6 inches long and connects the other end to thin clear plastic pipe.. if any one could tell me a part number or give me some idea of what to ask for that would be great. I was told it was part no 95 600 551 but it isn't!!
all i want for christmas is a dukla prague away kit
The fleet:
1992 Citroen BX 19TXD
1972 VW Camper
1969 Triumph Spitfire MKIII
1984 Kawasaki Z750
2002 Ibiza Seat
Re: hyrdaulic rubber hose 3mm internal diameter 150mm long
I believe you are referring to the security valve leak-off. You don't need to buy a special part - just some fuel hose from the local factor will sort it.
jamescarruthers
x 39
Post by jamescarruthers »
I haven't looked so this may be a dead end but may I reommend a boat Chandlers such as http://www.asap-supplies.com
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
nige
Post by nige »
hey guys many thanks... i found some 3.5mm fuel hose for an eberspacher fits a treat... delighted!
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
x 138
I find screenwash rubber tubing (available from most motor factors) and the plastic connectors and tee or y connectors are just the job for replacing low pressure return pipes available in 3 or 4mm diameter, makes replacing the rear axle return pipes a doddle.
This stuff is brilliant for this job, I keep a roll with my car;
http://www.beal.org.uk/hoses-tubing-fit ... _3121.html
nige
Post by nige »
as always some top advice .. thanks guys
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
