BX 19GT PROBLEM NO MORE!
Hi Guys
The normally totally reliable MK1 GT had developed an issue whilst being in storage
It starts ok from cold as usual but when it warms up and the auto choke comes off it dies the minute I touch the throttle, if I don't touch the throttle it will idle ok.
It then wont start although tries to fire and blows back and spits flames out of the carb! If I leave it overnight to cool it starts up ok.
I've replaced the fuel filter, it has plenty of petrol.
Carb or ignition problem?
Re: BX 19GT PROBLEMS
Carb problem. Possible the main jets are blocked up slightly. Best thing is to strip it and rebuild it (or get someone to do it for you).
I'm no expert on carbs, but I know it's easier to just rebuild the thing then to faff around trying to work out what's wrong. Solex Z1 kits are easily available, I've just done one on the AX GT (pretty much the same carb).
Is it still running the Solex carb? A Weber replacement is available and they tend to be more reliable.
The fuel will have gone off from being in storage and the jets might have become gummed up. When modern petrol evaporates it leaves behind a kind of varnish which causes umpteen problems with carbs. You can buy fuel stabilisers for vehicles which are used infrequently.
Solexes are fine if they're set up properly, to be fair.
The carb on this has been spot on for 8 years and starts well, I do have a spare weber but would prefer to stick with the original,
Is it worth giving it a good blast with Sold carb cleaner? A rebuild is not a problem,
How much fuel is in the tank Tim? Might be worth chucking some Millers Ecomax fuel treatment in the tank and going for a longish run out. If that doesn't improve matters then a carb rebuild and set up. Cheaper option first.
Is the auto choke disengaging I wonder? If it's staying on, then over fuelling could be causing it to cut out when the throttle is applied.
Post by Tinkley »
The Solex is OK. However when they are old some things deteriorate, namely the rubber/polymer parts in the carb. Best thing is the full seal kit which are stil available. You will NOT be able to change one part of the autochoke mechanism without breaking it, (not seen a replacement for this part btw), so leave this bit alone, however the diaghram withe the long L shaped metal rod is fairly critcal to getting the autochoke to work properly. I'd put money on yours being mighty stiff compared to a new part. Often this is most likely the only part you'll need to change.
Properly stripping the carb is pretty easy and all the passageways will blow clean with carb cleaner. Be careful with the diaghram in the accelerator pump ie note orientation, which face is the inner and don't lose the spring inside... so take off carefully. It may also be worth squeezing out the autocjoke waxstat working it to and fro and refitting. There is considerable spring pressure on this btw so be careful.. :wink:
Check the float weight it should be as per the manual 7 grams I think. If it is more chaneg the float, they become marginally heavy over time and don't work right if over 7.5 grams. Note you won't see petrol inside probably but it can still mean the plastic has started to absorb petrol in it's own grain structure.
Personally I'd also check the coil by substitution and maybe the ignition module, main earth, plus the exhaust manifold to down pipe gasket and spring strength after my recent experience with the auto. I'm assuming plugs, leads dizzy etc are all OK, sometimes a little corrosion on one of the contacts in the dizzy can be a big problem as can the main coil to dizzy HT lead. Pull all leads gently and inspect ends for corrosion.
You'll nail it Tim. Most of this stuff is pretty simple tbh, though really getting the carb fine tuned is a bit more tricky. Also you are right what seems like a carb problem often can be something else but at least if you go through it, generally you can eliminate each possible cause.
Post by ken newbold »
Only problem we ever had with our petrol BX was the distribution cap, the contacts on the underside got a build up of nasty crud, especially in the winter. A quick clean up and it was fine. Might be worth having a look in there
The auto choke is disengaging but I cant drive the car as when I touch the throttle it dies, I doubt its ignition related or surely it would do it all the time.
Post by Tinkley »
Not if the coil is failing, it will stall just as you try to pull away....ie max load. Had 2 go on the 14 and one on the 16. Our C4 has also just done the coilpack.... :wink: The 16/19 type will carry on working, though to be irritating if you let it get cold it will fire straight away!. If you have the gear it can be tested but you will find it may be out of range - capacitors tend to do this, or fail utterly.
But most likely the bottom of hte float is cruddy and a good clean will sort it. If there is a lot of rust in the float debris, suspect the steel fuel pipes, these also can leave a light petrol vapour a little above what you might expect if they are beginning to weep slightly.
Tim Leech wrote:The auto choke is disengaging but I cant drive the car as when I touch the throttle it dies, I doubt its ignition related or surely it would do it all the time.
Not necessarily, when it's ticking over there is very little load on it. So easy to check it out, have a look and see!
New coil ordered! Just in case.
I've spent very little on the GT mechanically so she's due some TLC. Plugs, fuel pump and filter, lhm change and some fresh oil.....ready for Holland!
Post by Tinkley »
If it is the coil, you will notice instantly the change in exhaust note. Helps the fuel consumption a lot too... :wink:
