Looks as tho your bottom pulley has sheared the keyway i would suspect the end of the crankshaft spline is knackered too.
I have a bottom pulley and key if you need one-from a diesel.
very lucky, well caught. Has it had the crank deal done and not had the pulley tightened properly perhaps?
