BX 1.6 TGS Athena rad.
Pedigreed
My Cars: BX Athena 1600
Post by Pedigreed »
Hi all, trying to locate a suitable radiator for above. Chassis VF7XBXB0059XB. Would have to be sent via carrier due to current restrictions.
x 117
Re: BX 1.6 TGS Athena rad.
Plenty of choice on ebay. Just be careful its exactly the one you want.
https://www.ebay.co.uk/itm/Nissens-Radi ... Sw5fBdqH3x
x 138
I have a good s/h rad from a gti8v, not sure it fits 16's, I know it fits variants of 19/19d plus others
I'm sure someone else will know fitments to answer this.
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 73
Post by white exec »
Check out Mister Auto as well.
Usually a good choice of makes there, including Nissens.
The site accepts original part numbers as well, so have that handy. If unsure, post your full VIN number, and we can look it up for you.
Mister Auto is owned by PSA.
white exec wrote: Sun Feb 07, 2021 4:17 pm Mister Auto is owned by PSA.
Is it? I thought their A/M division was Eurorepar?
white exec
x 73
Mister Auto is a division of PSA (ultimately Stellantis, now) specialising in the on-line 'sales of detachable parts' for PSA vehicles. There's a Wikipedia.fr page about them: https://fr.wikipedia.org/wiki/Mister-Auto.
Pedigreed
Post by Pedigreed »
Thanks all, will try all options and let you all know how I get on!
Pedigreed
Post by Pedigreed »
The measurements are 440 core length, 480 lower mountings and 380 height by 32 thickness of core. Hope this helps!
white exec
x 73
Do post your full VIN, if you'd like the Citroen part number, which will allow an accurate Mister Auto search, among other places.
Pedigreed
Post by Pedigreed »
Thanks Chris, full VIN is VF7XBXB0059XB3881
The 1.6 petrol manual had a smaller radiator than diesel and 1.9 petrol but one could be fitted I guess.
Ebays always worth a try as is the Facebook group
white exec
x 73
The range of radiators fitted to BX was/is lengthy.
Cit parts lump all these together (even for your VIN there is more than one listed), but my best find was
95 495 038 22dm² LAR600
for 1580cc with A/C (which yours is listed as having; it is also listed as a Millesime).
On Mister Auto, 95495038 throws up these two as replacements:
Nissens 61660, listed as 600mm
NRF 58683, listed as 600x378x34mm
Both, unfortunately showing Out of Stock on MA UK, although MA.es show 3 NRFs available.
If you need more help, can you post a photo of your existing rad (particularly to show the top of it and filler) and check dimensions of it?
BX 16 didn’t have a/c fitted unless it was a Mk1
white exec
x 73
Tim Leech wrote: Mon Feb 08, 2021 10:54 pm BX 16 didn’t have a/c fitted unless it was a Mk1
I was just going by Parts Characteristics, Tim:
RP 5190 = 24 Jan 1991
Pedigreed
Post by Pedigreed »
rutter123 wrote: Sun Feb 07, 2021 2:44 pm I have a good s/h rad from a gti8v, not sure it fits 16's, I know it fits variants of 19/19d plus others
Thanks for the offer! The core is 440 by 380 by 32 and the lower mounts are 480 apart.
