Rubbish.
Sticky back vinyl?
The wider wheels on the back could be an issue, shame cos I quite like that 70's look, you dig?
Height settings
Re: Height settings
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
ZX Volcane keeping others going - x 82
Re: Height settings
On normal height, mine is as follows.
Front floor to arch, 64cm.
Rear , 43cm.
That gives you a second set of figures if measuring "H" is not proving too easy.
Rear , 43cm.
Jugostran
- My Cars: 1989 Cimos-Citroƫn BX 16 TRS
2007 BMW 318d (Sold)
2019 Mazda 6 SkyActiv 165 MT - x 51
Re: Height settings
Mine recently had it's height corrected. Here's the image so you can compare. It is 16.5 cm front and 16.5 cm back in terms of measurement (from lowest point on sill to ground).rutter123 wrote: Sat Oct 01, 2022 1:56 pm Measured up today from bottom of sill to ground
Rear 9.5 inches
Front 8 inches
Little too high at rear, is it critical?![]()
Proud owner of a 1989 Yugoslavian Domestic Market Cimos-Citroƫn BX 16 TRS
Re: Height settings
Does anyone have a clear picture of where the rear height corrector rod goes through the pivot arm, my Haynes has been ruined by leaky roof.
Re: Height settings
I think is a little low at rear? Maybe it has sunk a bit.
My bro is coming today, gonna get the rear up on ramps weather permitting, to assist with some adjustments.
panky
'88 BX GTi (a long time ago) - x 175
Re: Height settings
Is this of any use. My manual gas been had by mice but this page was OKrutter123 wrote: Fri Oct 07, 2022 6:27 pm Does anyone have a clear picture of where the rear height corrector rod goes through the pivot arm, my Haynes has been ruined by leaky roof.
Re: Height settings
Mmm... As I thought something is amiss.
It appears in the bottom right pic headed REAR, where the height control rod enters the pivot it has 3 notches where the rod sits L1 and L2 in the pic, mine appears to be completely flat (worn away) along this edge so the rod is sitting "forward" permanently in position L2, hence this would throw the height out of sync?
I'm gonna remove the pivot and see if I can build it up with a bit of weld and file some new notches into it see if it makes a difference
Or if anyone has a good used one for grabs
Also noticed a weep on the h.c rubber cover, so I guess that'll be coming off as well for new seals.
- x 117
Re: Height settings
I think it is meant to be flat. What you have to do is to adjust the slider on the rod so that the rod is centred in the opening when the car is at normal height. As yours is not at normal height it is impossible to adjust correctly. Have you marked up the roll bar clamp yet and tried to adjust it to get the correct height.
The Joy of BX with just one Citroƫn BX to my name now. Will I sing Bye Bye to my GTI or will it be Till death us do part.
Re: Height settings
Not done anything yet John, I see what you mean tho, will set the rod to neutral and work from there, not touched the roll bar clamp yet that's all still as it was.
David
- x 60
Re: Height settings
The rod is flat on my car & on the parts car, so I think that they're supposed to be flat. Maybe the early mk1 cars had the notches, but not the rest? When the hydraulics are working correctly, and the car is in normal ride height, then the rod just sits in the middle anyway, even without any notches. I first saw it on mine when it was in a 4 post ramp.
Hope that helps.
Hope that helps.
1992 Citroƫn BX 1.9 Diesel Meteor 4x4 - The Project.
1992 Citroƫn BX 1.9 TXD (with GTI engine; Mulleys old car) - Parts car.
2004 Citroƫn Xsara Desire. (Now gone).
Re: Height settings
Yes it seems that's how it is, I'm gonna get it up on ramps at weekend and see what the score is, I've made a small jig with some wood so that when the axle settles onto it the height should be about right. Needs to drop about inch and half.
