BX 1990 19TZS for sale
Keeper of the site Goat
Post by cavmad »
Sleepy's AX is a little gem too, can understand why you don't want to get rid of it mate!
Vauxhall apologist.
sleepy0905
Post by sleepy0905 »
it just went throught its mot only needing wishbone bushes but they were the originals
ellevie
Forum Treasurer
Post by ellevie »
Is the coil in the 19TZS the round one mounted on the bulkhead behind the battery,
or is it the square type mounted near the engine?
David
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
wannab-x
Post by wannab-x »
Ooh, don't know. I can have a look, but that's likely to be at the weekend as there seems to be a curious lack of daylight by the time I get home after work these days... Don't know if the age (1990) would be any indication?
sleepy0905
If i remember correctly it is the square one near the engine
ellevie
Forum Treasurer
Post by ellevie »
Thanks for that, so it looks like it's the square one in the TZS.
Mark (mnde) recently had starting problems with his Meteor which he traced to a faulty square coil. Cacaolat also has ongoing starting problems with his Meteor which might well turn out to be his coil. The 19TRS and 19GT both have the round coil mounted on the bulkhead. I am beginning to suspect that the square coil might be a bit troublesome compared to the round ones. At any rate I've had my 19TRS since '92 and the coil is still fine. My other more recent 19TRS auto looks as if it's still on its original (round) coil.
David
BX19TXD 150k K Reg
wannab-x
Post by wannab-x »
If it helps, the diagnosis on my car's coil was slow as the coil was putting out a spark, but either the quality of spark was degrading once the coil was fitted back, or the spark wasn't quite good enough. At any rate, new coil & she started up straight away again.
Now, who wants the car??? :lol: I'm open to offers...
wannab-x
Post by wannab-x »
Right then, I need to get rid of this car - sadly - as it's taking up space. The post-Xmas bankruptcy period is over, I'm only looking for a couple of hundred - is anyone out there interested?
Thanks!
Andrew
