How to tow a crippled BX?
- BXpat
I might be taking on another Mk.1 TRD as a parts donor. Another Grandad BX - 31000 miles - ready to be sacrificed for the happiness of the others.
It runs but the system doesn't pressurise so somehow it's got to be pulled onto the trailer from its lowdown position. I know this has been done before but how?
mnde
- Meteor Man
I had my GSA recovered once with complete hydraulic failure.
The guy skilfully used wooden blocks/boards just next to the bottom of the ramp to provide enough clearance for the sump, underbody and exhaust system as he winched the car gently up the ramp onto the truck. Same at the top of the ramp to avoid catching the underside there. A stage by stage process, moving the blocks & boards as necessary.
Good luck!
Mark.
Good luck!
Mark.
M
Im sure there was a thread on the old Andyspares forum once about someone recovering an XM after total LHM failiure (sorry cant spell Hydraulic) using wooden blocks to wedge susension components after the car had been jacked up. Not sure how safe or viable that would be with a BX. Not something I would personally like to try. Perhaps someone has experience?
citroen7
Re: How to tow a crippled BX?
I need a few Mk1 bits todd so if it is a definate breaker I can possibly send you some euros!
- BXpat
- x 94
DavidRutherford
- BX Digit man!
This is possible only on a CX, and maybe on a GS. Impossible on anything with McPherson front struts.M wrote:Im sure there was a thread on the old Andyspares forum once about someone recovering an XM after total LHM failiure (sorry cant spell Hydraulic) using wooden blocks to wedge susension components after the car had been jacked up.
Amen bro!Kitch wrote:
Life is dishonest and unfair. Theres no god. It's all lies.
Todd, if it's just a spares car, just drag the bugger up, if something gets damaged, so what?!
It's possible to get a dead BX on a trailor without damage if you're careful, I've done it loads of times.
As said above, plenty of wood for taking the angle out of the ramp and away yer go!
I need the small blank that goes in the dash where a choke cable would be, plus the suport bracket that clamps to the battery tray that holds the air filter up, if its the same on diesel that is.toddao wrote:Thanks for all the suggestions. Just got to find a suitable tow vehicle now.
Tim, no matter how good it is, it will have to be broken as there's no space to store yet another 'restoration project'! What bits do you need?
Aerodynamica
- x 114
Actually you can keep the rear suspension permanently on high on a dead BX.
How ?
Get a broom handle or similar. Cut a length of 32cm (I think). Jack up and remove a sphere and shove the wood into the suspension cylinder. Refit the sphere and this will do the job of the hydraulics.
How ?
- BXpat
Thanks for all the excellent suggestions!
Mat, I would tow it with my van but it's been de-registered until next Spring to save money as we never use it in Winter..
The father-in-law however has got a Merc 609D van that would do the job nicely. Problem is, he already thinks I've got too many BXs, though catch him in the right moment and I reckon he might be up for the caper or lend me the thing?
Anyway, the guy with the TRD wants it away so I've got to decide and act by next weekend. Two hour journey each way but then it's a complete parts bin.
Ah, yes one more thing - slight technical hitch with the wife. Maybe I'll be asking how to convert a BX into a bender/fall out shelter. I managed to get number three in under the radar but she really doesn't get it, what with the new kid etc. How to tow a crippled BX enthusiast??
Watch this space..
Watch this space..
- x 94
