I'd be grateful for advice about fixing some knocks ad rattles from my front end.
Do I need to replace the whole wishbone (suspension arm?) or is okay just to do the ball joint? I was quoted £70 for the wishbone/suspension arm, but £8 for just the ball joint. There is certainly play in the ball joints and the drop links, should I be looking anywhere else as well?
Thanks (and sorry, I guess this subject has been discussed before, I just like the personal touch ).
scarecrow wrote:knocks ad rattles from my front end
Isn't that just old age?
Euro Car Parts do the wishbones, complete with bushes for under £30 a side. Not sure what the bushes cost on their own but it would save you having to press them in.
That wouldn't solve the ball joint problem though...and drop links are a separate item as well! So if the bushes are OK I wouldn't worry about the wishbones.
Ahh, therein lies the crux - am I right in thinking that it won't be possible to tell if the bushes are worn until the ball joints are replaced? As I'm not doing it, and the car has to be fixed during one evening, I might be better getting the wishbones replaced at the same time.
Thanks for the EuroCarParts link Mat.
Edit: What's a Lemforder Ball Joint (LH, RH, FR LH/RH) as opposed to the normal one? Is it just a quality thing?
Yes, they're a big German name, OE equipment to BMW and I think were the OE suppliers for the BX stuff too. Lemforder BJs (have to be careful where I use that abbreviation) are available cheaper from AEP, who I've had good dealings with. They're cheaper for OE drop links too but don't list the bushes or wishbones (may be worth a call though, if you get the total over £50 it's free postage).
My plan is to try the ECP wishbones but keep the old ones to refurb in my own time as and when I can get OE quality bushes cheaply. Mine haven't got any play but are starting to crack a little so are on their way out.
No - the bushes are the bits around which the wishbone rotates...
A quick Google search later and this (not for a BX) shows bushes at the lower/LH end and a ball joint at the upper/RH end. On the BX the BJ is screwed into the hub carrier and a taper joint into the wishbone, so any wishbones are unlikely to come with BJs.
For £30 a side you's be mad not too!
I had no idea they were kncoking them out so cheap!
After spending £50 on genuine bloody bushes for mine aswell...
Oh well...
From experience most of the knocking comes from the ball joints and the drop links - it's hard to feel the play in the drop links when it's all fitted as the tension in the anti-roll bar takes it up. Fitting new ball joints and links got rid of all my TZD's front end rattles even though I can easily feel the wear in the wishbone bushes. The main reason I haven't got round to changng the wishbones yet (I've got new genuine ones on the shelf) is I haven't yet managed to undo the main nuts, let alone shift the through-bolt/pin...
I'd suggest leaving more than one evening for the job, especially if you're doing it for the first time!
Thanks exactly what the mechanic said Kev! He was telling me about how he has had to cut bits off with a little piece of hacksaw blade.
And thanks too to Malcolm - I didn't know that about the bushes.
I'm in a bit of a dilemma as someone has offered to fix the car quite cheaply - but I'm not sure how much it should cost. I got an estimate of £70 a side for the ball joints...EDIT: garage estimate including parts, the other estimate was £20 just for labour.
I received my new drop-links and ball joints from AEP yesterday. They must have been out of stock on the cheaper balljoints as they've sent me Lemforder's at no extra cost! I didn't get the wishbones as I only have access to a ramp for one evening, they'll have to wait for another day.
Only if you can think up another imaginative use for them…you need 2 in total, 1 per side! I'm confused though - did you actually get the BJs from GSF as AEP only list the Lemforder type?
